[GRASS-user] Missing some tools: v.db.addcol, for example
Roger André randre at gmail.com
Thu Oct 15 11:00:24 EDT 2009
Thanks,
My PATH while in GRASS already contains the scripts dir:
GRASS 6.4.0RC4 (colombia):~ > echo $PATH
/usr/local/grass-6.4.0RC4/bin:/usr/local/grass-6.4.0RC4/scripts:<snip>
What I did find is that each script is under a directory by the same
name in the scripts dir.  So for example, d.redraw is in:
/usr/local/grass-6.4.0RC4/scripts/d.redraw/d.redraw
I'm going through all of these now, and removing the dir and leaving
the script.  Somewhat tedious, but the scripts appear to work.
Roger
On Wed, Oct 14, 2009 at 10:34 PM, Hamish <hamish_b at yahoo.com> wrote:
> Roger André wrote:
>> I've noticed that a few tools in my GRASS 6.4 appear to be
>> missing, or at least missing from my path.
> from the GRASS terminal, what does "echo $PATH" say?
>> Here is an example:
>> bash: v.db.addcol: command not found
>> And yet, when I look for the tool under my install dir, it
>> appears to be there:
>> $ find /usr/local/grass-6.4.0RC4 -name "v.db.addcol*"
>> /usr/local/grass-6.4.0RC4/dist.i686-pc-linux-gnu/scripts/v.db.addcol
>> It's only a problem with certain tools.  I have the same
>> problem with d.redraw for example, but not with d.erase.
> d.redraw is another shell script like v.db.addcol found in
> $GISBASE/scripts. d.erase is a C program found in $GISBASE/bin/
>> Is there some way I can add the scripts tools back in, and
>> is this the sign that I just screwed up the install somehow?
> check to see that the scripts dir made it into the PATH, if not,
> add it.
> PATH="$PATH:$GISBASE/scripts"
> export PATH
> No idea why that would fail.
> Hamish
