[GRASS-user] Importing Vector Data
    Roger André
    randre at gmail.com
    Fri Oct 16 14:22:20 EDT 2009
Hi Bob,
Just starting to use GRASS myself, so this certainly isn't an expert
opinion. You can reproject the data using ogr2ogr without having to
bring it into GRASS at all.
The best resource I have found so far for GRASS is the book by Neteler
and Mitasova, "Open Source GIS, a GRASS GIS Approach".  It's not
cheap, but it seems to cover all the issues you are going to
encounter, including this one. It recommends that to import the data,
you should create a new location with the GUI and use the data set to
define the extents, then import the data using the v.in.ogr tool.
Apologies if that's old news to you, it's still relatively new to me.
Roger
On Fri, Oct 16, 2009 at 9:15 AM, Bob Byer <hydrogeo_1 at yahoo.com> wrote:
> All,
> I work extensively in the state of Delaware and the mapping information that
> they provide is based on ESRI ID 102257 with an ESRI WKT Name of
> NAD_1983_HARN_StatePlane_Delaware_FIPS_0700.  As a new user of GRASS, what
> would be the best way to import that data?  Ultimately, I wish to reproject
> state plane meters to state plane feet then use those files to import into a
> MODFLOW project.  Perform the modeling, then export that information back to
> GRASS for additional processing.
> In case there is interest, the web site
> http://datamil.delaware.gov/geonetwork/srv/en/datadownload
> Thanks in advance,
> Bob
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
