[GRASS-user] Missing some tools: v.db.addcol, for example
Roger André
randre at gmail.com
Fri Oct 16 14:26:09 EDT 2009
Hi Nikos,
I downloaded the source, grass-6.4.0RC4.tar.gz, unpacked it into
/usr/local, and then ran the following commands:
- Install GRASS
- needs Tcl/tk
$ sudo apt-get install tcl8.4 tcl8.4-dev tk8.4 tk8.4-dev
- needs fftw
$ sudo apt-get install fftw-dev
$ sudo ./configure --with-python
--with-gdal=/usr/local/bin/gdal-config
--with-tcltk-includes=/usr/include/tcl8.4
--with-postgres-includes=/usr/local/postgresql-8.3.5/src/include
-with-postgres-libs=/usr/local/postgresql-8.3.5/src/include/lib
--with-cxx
$ sudo make
$ sudo make install
On Fri, Oct 16, 2009 at 11:05 AM, Nikos Alexandris
<nikos.alexandris at felis.uni-freiburg.de> wrote:
> Roger André wrote:
>> Hi Markus,
>> Thanks for your inquiry about this. Everything works now, after
>> having moved all scripts from sub-directory into $GISBASE/scripts.
>> I'm teaching myself how to use GRASS with your excellent book, so I am
>> far from being an expert at installation and configuration options.
>> However in response to Nikos's question, I am not sure how changing
>> permissions would have solved this problem.
> My bad Roger. I was looking at the source code tree.
>> Following the defined
>> $PATH would only bring you to the directory, and not the script
>> itself. It would seem to me that part of the make process would be to
>> copy these scripts into the correct directory, but since they appear
>> to be the same place... I dunno.
> How did you perform the installation, if I may ask?
> Nikos
>> On Fri, Oct 16, 2009 at 6:08 AM, Nikos Alexandris
>> > On Fri, 2009-10-16 at 15:01 +0200, Nikos Alexandris wrote:
>> >> > > On Thu, Oct 15, 2009 at 5:00 PM, Roger André <randre at gmail.com> wrote:
>> >> > > > My PATH while in GRASS already contains the scripts dir:
>> >> > > > GRASS 6.4.0RC4 (colombia):~ > echo $PATH
>> >> > > > /usr/local/grass-6.4.0RC4/bin:/usr/local/grass-6.4.0RC4/scripts:<snip>
>> >> > Mine too (the grass-6.4.0svn version).
>> >> > > > What I did find is that each script is under a directory by the same
>> >> > > > name in the scripts dir. So for example, d.redraw is in:
>> >> > > > /usr/local/grass-6.4.0RC4/scripts/d.redraw/d.redraw
>> >> > On Fri, 2009-10-16 at 11:44 +0200, Markus Neteler wrote:
>> >> > > Wow. This is not desired of course. I am a bit surprised.
>> >> On Fri, 2009-10-16 at 12:18 +0200, Nikos Alexandris wrote:
>> >> [Replying to myself]
>> >> > Maybe I don't get that right but I have grass64_release, grass640_0rc5,
>> >> > grass6_devel, grass_trunk. In all of them the scripts (sub-)directory
>> >> > contains a directory for each script. In each script-directory there are
>> >> > description (html) files and also README, Makefiles, etc.
>> >> > Isn't this ok?
>> >> Yes it is (for the source code :-). Under /usr/local/grass... (the
>> >> installed stuff; currently I use the 64 version) all scripts are bare
>> >> files under the scripts directory.
>> >> > > > I'm going through all of these now, and removing the dir and leaving
>> >> > > > the script. Somewhat tedious, but the scripts appear to work.
>> >> > > Would you mind to check if this is still valid for RC5?
>> > I've installed grass-6.4.0RC5 and there is no problem. Scripts (all of
>> > them I suppose seem to) work fine ~ I 've tested several.
>> > Nikos
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
