[GRASS-user] Missing some tools: v.db.addcol, for example
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Fri Oct 16 14:54:45 EDT 2009
Roger André:
> Hi Nikos,
> I downloaded the source, grass-6.4.0RC4.tar.gz, unpacked it into
> /usr/local,
hmm?
If you have a tarred source named "grass-6.4.0RC4.tar.gz" after
unpacking it you get a directory called grass-6.4.0RC4. The installation
process installs over it at "/usr/local/grass-6.4.0RC4/" as I can see in
your first post, then this should be the root of the problem.
Perhaps its better to move the source tree somewhere else
(e.g. /usr/local/src).
> and then ran the following commands:
> - Install GRASS
> - needs Tcl/tk
> $ sudo apt-get install tcl8.4 tcl8.4-dev tk8.4 tk8.4-dev
> - needs fftw
> $ sudo apt-get install fftw-dev
> $ sudo ./configure
Better to use pure "./configure" here.
> --with-python
> --with-gdal=/usr/local/bin/gdal-config
> --with-tcltk-includes=/usr/include/tcl8.4
> --with-postgres-includes=/usr/local/postgresql-8.3.5/src/include
> -with-postgres-libs=/usr/local/postgresql-8.3.5/src/include/lib
> --with-cxx
> $ sudo make
Here too, use pure "make".
> $ sudo make install
Hope this helps :-)
Nikos
