[GRASS-user] can't ingest an E00 file using r.in.gdal,
or anything else?
Jeff Hamann
jeff.hamann at forestinformatics.com
Sat Oct 17 11:07:56 EDT 2009
I'm not sure why this is not working, and I'm having a little trouble
getting a satisfactory answer on the web.
I'm trying to import an e00 file (arc/info grid) using r.in.gdal. For
example,
GRASS 6.4.0svn (himom):~/Documents/rufus/incoming/wadnr > r.in.gdal
input=lewis_dem30.e00 output=lewisdem location=himom2 --verbose
ERROR 4: `lewis_dem30.e00' not recognised as a supported file format.
from outside GRASS,
Jeff-Hamanns-MacBook-Pro:lewis_dir hamannj$ gdalinfo lewis_dem30.e00
gdalinfo failed - unable to open 'lewis_dem30.e00'.
and the file looks like this:
Jeff-Hamanns-MacBook-Pro:lewis_dir hamannj$ head lewis_dem30.e00
EXP 0 /AM/PROCESS/DATASERVICES/LEWIS_DIR/LEWIS_DEM30.E00
GRD 2
4860 1539 1-0.21474836470000E+10
0.10435500000000E+03 0.10435500000000E+03
0.91924128086325E+06 0.38480838058312E+06
0.14264065808632E+07 0.54541072558312E+06
-2147483647 -2147483647 -2147483647 -2147483647 -2147483647
Any hints? What kind of file is this, really?
Thanks,
Jeff.
Jeff Hamann, PhD
PO Box 1421
Corvallis, Oregon 97339-1421
541-754-2457
jeff.hamann[at]forestinformatics[dot]com
http://www.forestinformatics.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091017/5ecc7357/attachment.html
