[GRASS-user] can't ingest an E00 file using r.in.gdal, or
anything else?
Jamie Adams
jaadfoo at gmail.com
Sat Oct 17 12:33:51 EDT 2009
Hey Jeff,
This is a valid file, though not well supported by software other than ESRI.
E00 files most commonly hold vector formats, but can be used to contain
raster data also. AFAIK, there is no way to import these directly into
GRASS, it only supports the vector version with v.in.e00
For this reason, I keep a little ESRI utility around just in case:
http://www.esri.com/apps/products/download/?downloadid=175
<http://www.esri.com/apps/products/download/?downloadid=175>It's a Windows
binary, and requires registration, but it works. I've successfully run it
using Wine on Linux, probably will work on a Mac also. I reads the e00 file
and dumps an arcinfo binary grid where you specify.
Hope this helps.
Jamie
On Sat, Oct 17, 2009 at 8:07 AM, Jeff Hamann <
jeff.hamann at forestinformatics.com> wrote:
> I'm not sure why this is not working, and I'm having a little trouble
> getting a satisfactory answer on the web.
> I'm trying to import an e00 file (arc/info grid) using r.in.gdal. For
> example,
> GRASS 6.4.0svn (himom):~/Documents/rufus/incoming/wadnr > r.in.gdal
> input=lewis_dem30.e00 output=lewisdem location=himom2 --verbose
> ERROR 4: `lewis_dem30.e00' not recognised as a supported file format.
> from outside GRASS,
> Jeff-Hamanns-MacBook-Pro:lewis_dir hamannj$ gdalinfo lewis_dem30.e00
> gdalinfo failed - unable to open 'lewis_dem30.e00'.
> and the file looks like this:
> Jeff-Hamanns-MacBook-Pro:lewis_dir hamannj$ head lewis_dem30.e00
> EXP 0 /AM/PROCESS/DATASERVICES/LEWIS_DIR/LEWIS_DEM30.E00
> GRD 2
> 4860 1539 1-0.21474836470000E+10
> 0.10435500000000E+03 0.10435500000000E+03
> 0.91924128086325E+06 0.38480838058312E+06
> 0.14264065808632E+07 0.54541072558312E+06
> -2147483647 -2147483647 -2147483647 -2147483647 -2147483647
> Any hints? What kind of file is this, really?
> Thanks,
> Jeff.
> Jeff Hamann, PhD
> PO Box 1421
> Corvallis, Oregon 97339-1421
> 541-754-2457
> jeff.hamann[at]forestinformatics[dot]com
> http://www.forestinformatics.com
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091017/d979fb6e/attachment.html
