[GRASS-user] import GeoPDF into GRASS: projection and boundaries
of GeoPDF file?
Boris.Vasiliev at forces.gc.ca
Mon Oct 19 10:29:03 EDT 2009
Unfortunately GDAL does not recognize GeoPDF format:
gdalinfo in-geo.pdf
yields
ERROR 4: `in-geo.pdf` not recognized as a supported file format.
followed by a print-out of backtrace information.
Regards,
Boris.
-----Original Message-----
Sent: Friday, 16, October, 2009 21:07 PM
To: grass-user at lists.osgeo.org; Vasiliev B at CEFCOM HQ at Ottawa-Hull
Subject: Re: [GRASS-user] import GeoPDF into GRASS: projection and boundaries of GeoPDF file?
Boris wrote:
> I would like to ask for suggestions on extraction of image projection
> and boundaries from GeoPDF files.
> In particular, I have a high-resolution areal photo saved as a GeoPDF
> file that I would like to import as a raster image into GRASS. At
> this time, GDAL does not support conversion of GeoPDF files to other
> geo-referenced raster formats and the following steps may be necessary
> to import the areal photo into GRASS:
> - import .jpg file into GRASS with r.in.gdal
> - specify image projection and boundaries with r.region
Does GDAL support it even minimally?
ie does `gdalinfo` give the image bounds?
Hamish
