[GRASS-user] Help creating dissolved multipolygon
Roger André
randre at gmail.com
Tue Oct 20 16:37:30 EDT 2009
Hi all,
I'm having trouble creating a single, dissolved feature and exporting
it as a multipolygon. Here is what I've done:
- layer I started with:
> v.info -t global_mask
nodes=5448
points=0
lines=0
boundaries=2727
centroids=2723
areas=2723
islands=2721
faces=0
kernels=0
primitives=5450
map3d=0
- added dissolve field:
> v.db.addcol global_mask col="diss int"
> v.db.update global_mask col=diss value=1
- check that diss field is there:
> v.info -c global_mask
Displaying column types/names for database connection of layer 1:
INTEGER|cat
DOUBLE PRECISION|cat_
INTEGER|diss
- dissolve:
v.dissolve global_mask out=new_mask col=diss --o
- inspect new layer:
> v.info -t new_mask
nodes=5448
points=0
lines=0
boundaries=2727
centroids=2723
areas=2723
islands=2721
faces=0
kernels=0
primitives=5450
map3d=0
- export layer as shapefile:
> v.out.ogr -p input=new_mask type=area dsn=/tmp olayer=new_mask
- check new shapefile:
ogrinfo -summary /tmp new_mask
INFO: Open of `/tmp'
using driver `ESRI Shapefile' successful.
Layer name: new_mask
Geometry: Polygon
Feature Count: 2723
Extent: (-180.000000, -90.000000) - (180.000000, 83.623596)
Layer SRS WKT:
GEOGCS["GCS_WGS_1984",
DATUM["WGS_1984",
SPHEROID["WGS_1984",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]]
cat: Real (11.0)
As you can see, I still have 2723 features, when I expect to have 1.
What am I doing wrong?
Roger
