[GRASS-user] i.in.spot.vgt
alfreale alfreale74 at gmail.com
Thu Oct 22 06:17:14 EDT 2009
I've some error when import spot vegetation images with i.in.spot.vgt script
(GRASS 6.4.0RC5):
GRASS 6.4.0RC5 (wgs84_lat_long):~ > i.in.spotvgt -a --overwrite --verbose
file=/media/Archivio_Esterno/DE_archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980401_NDVI__Africa/0001/0001_NDV.HDF
rast=ndvi_test
Importing SPOT VGT NDVI map...
Warning 6: A dataset opened by GDALOpenShared should have the same filename
(/media/Archivio_Esterno/DE_archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980401_NDVI__Africa/0001/0001_NDV.HDF)
and description
(HDF4_SDS:UNKNOWN:"/media/Archivio_Esterno/DE_archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980401_NDVI__Africa/0001/0001_NDV.HDF":0)
Projection of input dataset and current location appear to match
Proceeding with import...
 100%
Setting grey color table for <ndvi_test> (8bit, full range)
r.in.gdal complete. Raster map <ndvi_test> created.
Imported SPOT VEGETATION NDVI map <ndvi_test>.
Remapping digital numbers to NDVI...
 100%
Importing SPOT VGT NDVI quality map...
ERROR 4:
`/media/Archivio_Esterno/DE_archivio/cartografia/satellite/spot_vegetation_Africa/V1KRNS10__19980401_SMI__Africa/0001/0001_SM.HDF'
does not exist in the file system,
and is not recognised as a supported dataset name.
ERROR: An error occurred. Stop.
Thanks,
Alfredo
View this message in context: http://n2.nabble.com/i-in-spot-vgt-tp3871408p3871408.html
Sent from the Grass - Users mailing list archive at Nabble.com.
