[GRASS-user] Specifying a colour for EPS files used as a fill
	pattern
    Casey Vandenberg
    casey.vandenberg at sjgeophysics.com
    Thu Oct 22 13:48:08 EDT 2009
I have a pattern file of a wetland in .eps format. The .eps file was
created from an svg file using inkscape. The output .eps file that was
created had a colour specified as black (0 0 0 setrgbcolor) when opened
with a text editor. I created two additional eps files based on this
original one. In one eps file, I had changed the colour to blue (0 0 1
setrgbcolor) and the other had no colour specified at all (all instances
of setrgbcolor were removed using a text editor). When I use any of
these files as the vareas fill pattern file in my .psmap instructions,
they always display as white. My color and fcolor variables are set as
blue. Am I missing something? How would can I set the colour of my fill
pattern?
Thanks,
Casey
Type: image/x-eps
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20091022/08252859/Wetland.bin
