[GRASS-user] v.vol.rst error
xavier garcia acosta epistacio at hotmail.com
Tue Sep 1 04:03:27 EDT 2009
> From: neteler at osgeo.org
> Date: Mon, 31 Aug 2009 22:42:05 +0200
> Subject: Re: [GRASS-user] v.vol.rst error
> To: epistacio at hotmail.com
> CC: grass-user at lists.osgeo.org
> On Mon, Aug 31, 2009 at 7:26 PM, xavier garcia
> acosta<epistacio at hotmail.com> wrote:
> > Hello all,
> > I would like to use the v.vol.rst module but when I try to execute them from
> > the GRASS GUI this error text appears in the terminal:
> > GRASS 6.4.0RC4 (costabrava):~ > *** buffer overflow detected ***: v.vol.rst
> > terminated
> > ======= Backtrace: =========
> > /lib/tls/i686/cmov/libc.so.6(__fortify_fail+0x48)[0xb7792da8]
> > /lib/tls/i686/cmov/libc.so.6[0xb7790eb0]
> > /lib/tls/i686/cmov/libc.so.6[0xb77905a8]
> > /lib/tls/i686/cmov/libc.so.6(__overflow+0x53)[0xb7703683]
> > /lib/tls/i686/cmov/libc.so.6(__printf_fp+0x176e)[0xb76db26e]
> > /lib/tls/i686/cmov/libc.so.6(_IO_vfprintf+0x3ca)[0xb76d4bfa]
> > /lib/tls/i686/cmov/libc.so.6(__vsprintf_chk+0xa4)[0xb7790654]
> > /lib/tls/i686/cmov/libc.so.6(__sprintf_chk+0x2d)[0xb779059d]
> > v.vol.rst(main+0x176)[0x804c966]
> > /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0xb76ab775]
> > v.vol.rst[0x804bd71]
> > ======= Memory map: ========
> > 08048000-08056000 r-xp 00000000 08:06 347205
> > /usr/lib/grass64/bin/v.vol.rst
> > 08056000-08057000 r--p 0000d000 08:06 347205
> > 08057000-08058000 rw-p 0000e000 08:06 347205
> > 08a25000-08a46000 rw-p 08a25000 00:00 0          [heap]
> > Anybody know how to fix that?
> > Pd: My GRASS version is GRASS 6.4.0RC4 (2009) runnig on UBUNTU 9.04
> I have used v.vol.rst in GRASS 6.4 for more than 22000 UTM maps
> without problems.
> Please tell use the parametes you used (idealy the command line), or,
> even better, an example to reproduce it with either Spearfish or the
> North Carolina
> data set. Which projection?
> Markus
The fact is that I had just tried to execute this module from the GRASS GUI, without include any parameter. Then I have tried execute the module in the terminal and the result is exactly the same, with or without parameters:
GRASS 6.4.0RC4 (costabrava):~ > v.vol.rst input=string [cellinp=dtm] [wcolumn=DIESPLUJA] [cellout=diespluja]
*** buffer overflow detected ***: v.vol.rst terminated
/lib/tls/i686/cmov/libc.so.6(__fortify_fail+0x48)[0xb77d0da8]
/lib/tls/i686/cmov/libc.so.6[0xb77ceeb0]
/lib/tls/i686/cmov/libc.so.6[0xb77ce5a8]
/lib/tls/i686/cmov/libc.so.6(__overflow+0x53)[0xb7741683]
/lib/tls/i686/cmov/libc.so.6(__printf_fp+0x176e)[0xb771926e]
/lib/tls/i686/cmov/libc.so.6(_IO_vfprintf+0x3ca)[0xb7712bfa]
/lib/tls/i686/cmov/libc.so.6(__vsprintf_chk+0xa4)[0xb77ce654]
/lib/tls/i686/cmov/libc.so.6(__sprintf_chk+0x2d)[0xb77ce59d]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0xb76e9775]
08048000-08056000 r-xp 00000000 08:06 347205     /usr/lib/grass64/bin/v.vol.rst
08056000-08057000 r--p 0000d000 08:06 347205     /usr/lib/grass64/bin/v.vol.rst
08057000-08058000 rw-p 0000e000 08:06 347205     /usr/lib/grass64/bin/v.vol.rst
08efe000-08f1f000 rw-p 08efe000 00:00 0          [heap]
b5a1b000-b5a5a000 r--p 00000000 08:06 81613      /usr/lib/locale/ca_ES.utf8/LC_CTYPE
b5a5a000-b5a5e000 rw-p b5a5a000 00:00 0
b5a5e000-b5a61000 r-xp 0
My projection is: 1 (UTM)
zone:       31
datum:      eur50
Xavier
_________________________________________________________________
Comparte tus mejores momentos del verano ¡Hazlo con Windows Live Fotos!
http://www.vivelive.com/compartirfotos
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090901/09fd8756/attachment.html
