[GRASS-user] v.vol.rst error
xavier garcia acosta epistacio at hotmail.com
Tue Sep 1 11:50:23 EDT 2009
To: grass-user at lists.osgeo.org
Subject: RE: [GRASS-user] v.vol.rst error
Date: Tue, 1 Sep 2009 08:03:27 +0000
> From: neteler at osgeo.org
> Date: Mon, 31 Aug 2009 22:42:05 +0200
> Subject: Re: [GRASS-user] v.vol.rst error
> To: epistacio at hotmail.com
> CC: grass-user at lists.osgeo.org
> On Mon, Aug 31, 2009 at 7:26 PM, xavier garcia
> acosta<epistacio at hotmail.com> wrote:
> > Hello all,
> > I would like to use the v.vol.rst module but when I try to execute them from
> > the GRASS GUI this error text appears in the terminal:
> > GRASS 6.4.0RC4 (costabrava):~ > *** buffer overflow detected ***: v.vol.rst
> > terminated
> > ======= Backtrace: =========
> > /lib/tls/i686/cmov/libc.so.6(__fortify_fail+0x48)[0xb7792da8]
> > /lib/tls/i686/cmov/libc.so.6[0xb7790eb0]
> > /lib/tls/i686/cmov/libc.so.6[0xb77905a8]
> > /lib/tls/i686/cmov/libc.so.6(__overflow+0x53)[0xb7703683]
> > /lib/tls/i686/cmov/libc.so.6(__printf_fp+0x176e)[0xb76db26e]
> > /lib/tls/i686/cmov/libc.so.6(_IO_vfprintf+0x3ca)[0xb76d4bfa]
> > /lib/tls/i686/cmov/libc.so.6(__vsprintf_chk+0xa4)[0xb7790654]
> > /lib/tls/i686/cmov/libc.so.6(__sprintf_chk+0x2d)[0xb779059d]
> > v.vol.rst(main+0x176)[0x804c966]
> > /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe5)[0xb76ab775]
> > v.vol.rst[0x804bd71]
> > ======= Memory map: ========
> > 08048000-08056000 r-xp 00000000 08:06 347205
> > /usr/lib/grass64/bin/v.vol.rst
> > 08056000-08057000 r--p 0000d000 08:06 347205
> > 08057000-08058000 rw-p 0000e000 08:06 347205
> > 08a25000-08a46000 rw-p 08a25000 00:00 0          [heap]
> > Anybody know how to fix that?
> > Pd: My GRASS version is GRASS 6.4.0RC4 (2009) runnig on UBUNTU 9.04
> I have used v.vol.rst in GRASS 6.4 for more than 22000 UTM maps
> without problems.
> Please tell use the parametes you used (idealy the command line), or,
> even better, an example to reproduce it with either Spearfish or the
> North Carolina
> data set. Which projection?
> Markus
I have solved the last problem but now when I exectute v.vol.rst module with the next command:
v.vol.rst input=puntsestacio at pobles cellinp=dtm at clima wcolumn=DIESPLUJA tension=40. smooth=0.1 segmax=700 npmin=200 dmin=15.001074 wmult=1.0 zmult=1.0 cellout=diespluja2
I've got the next error:
"Percent complete: WARNING: Reading raster map <dtm at clima> request for row 3231 is outside region
ERROR: Could not get row (eventually WIND3 does not match WIND)"
Anybody know how to solve that?
_________________________________________________________________
Messenger cumple 10 años ¡Descárgate ya los nuevos emoticonos!
http://www.vivelive.com/felicidades
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090901/67f7b432/attachment-0001.html
