[GRASS-user] Re: Projrction and transformation
kapo coulibaly
kmcoulib at gmail.com
Tue Sep 1 10:21:09 EDT 2009
Hi Ambrish,
I found that what works for me is to create two different locations, one
with Lat-Long coordinate definition and one with UTM. Then use r.proj or
v.proj to import from your Lat-Long to your UTM location. That way they line
up perfectly because GRASS will reproject "on the fly" between two locations
with properly defined projection parameters.
Hope it helps
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090901/841b99aa/attachment.html
