[GRASS-user] Re: Projrction and transformation
    Micha Silver
    micha at arava.co.il
    Tue Sep  1 10:28:55 EDT 2009
kapo coulibaly wrote:
> Hi Ambrish,
> I found that what works for me is to create two different locations,
> one with Lat-Long coordinate definition and one with UTM. Then use
> r.proj or v.proj to import from your Lat-Long to your UTM location.
> That way they line up perfectly because GRASS will reproject "on the
> fly" between two locations with properly defined projection parameters.
What v|r.proj do is create a *new* data layer, a copy of the original,
projected into the new CRS. So this is not really "on-the-fly"
reporjection. Just a point of semanitics...
Micha
> Hope it helps
> This mail was received via Mail-SeCure System.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
