[GRASS-user] Possible bug in v.edit
Martin Landa
landa.martin at gmail.com
Tue Sep 1 10:29:22 EDT 2009
2009/9/1 Marc-Antoine Nüssli <marc-antoine.nuessli at euratlas.com>:
> I have tested with Grass 6.3 AND grass 6.4(the one on which I'm working on)
6.4 from SVN (revision?) or RC?
> Did you use any special parameter during the import (apart from setting the
> format to standard) ?
I used the ASCII vector map you have attached (v.in.ascii format=standard)
> The only other possibility that I can see is the OS. I'm currently testing
> on windows.
I don't think so.
> Are you also on windows or on Linux?!?
GNU/Linux
> Have you also tried to select from layer 2 ? (v.edit map=test layer=2
> tool=select cats=2 type=centroid --q)
24,26,29
Seems to be reasonable.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
