[GRASS-user] Possible bug in v.edit
Marc-Antoine Nüssli marc-antoine.nuessli at euratlas.com
Tue Sep 1 10:48:46 EDT 2009
> I have tested with Grass 6.3 AND grass 6.4(the one on which I'm working
on)
6.4 from SVN (revision?) or RC?
6.4RC5
What about you?
I guess I should try with the latest SVN...
> Did you use any special parameter during the import (apart from setting
the
> format to standard) ?
I used the ASCII vector map you have attached (v.in.ascii format=standard)
Ok, so that's not related to that.
> The only other possibility that I can see is the OS. I'm currently testing
> on windows.
I don't think so.
Yes, that would be very strange...
> Are you also on windows or on Linux?!?
GNU/Linux
> Have you also tried to select from layer 2 ? (v.edit map=test layer=2
> tool=select cats=2 type=centroid --q)
24,26,29
Seems to be reasonable.
yes indeed...
ma
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090901/04150112/attachment.html
