[GRASS-user] Possible bug in v.edit
Marc-Antoine Nussli
marc-antoine.nuessli at euratlas.com
Tue Sep 1 12:46:13 EDT 2009
Ok, so it is definitively related to the OS...
I've just tested it right now on GNU/Linux and everything work correctly.
Then, I've tested it again on Windows(but on a different computer than
this afternoon) and it didn't work.
So, to summarize:
Grass 6.3 Release - Win32 (precompiled binaries) - computer A : BAD
Grass 6.4RC5 - Win32 (compiled by myself) - computer A: BAD
Grass 6.4RC5 - Win32 (compiled by myself) - computer B: BAD
Grass 6.4RC5 - Linux (compiled by myself) - computer B: OK
Maybe someone else who works on Windows can confirm the problem?!?
MA
> > I have tested with Grass 6.3 AND grass 6.4(the one on which I'm
> working on)
> 6.4 from SVN (revision?) or RC?
> 6.4RC5
> What about you?
> I guess I should try with the latest SVN...
> > Did you use any special parameter during the import (apart from
> setting the
> > format to standard) ?
> I used the ASCII vector map you have attached (v.in.ascii
> format=standard)
> Ok, so that's not related to that.
> > The only other possibility that I can see is the OS. I'm
> currently testing
> > on windows.
> I don't think so.
> Yes, that would be very strange...
> > Are you also on windows or on Linux?!?
> GNU/Linux
> > Have you also tried to select from layer 2 ? (v.edit map=test
> layer=2
> > tool=select cats=2 type=centroid --q)
> 24,26,29
> Seems to be reasonable.
> yes indeed...
> ma
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
