[GRASS-user] Possible bug in v.edit
Daniel Victoria daniel.victoria at gmail.com
Tue Sep 1 20:14:04 EDT 2009
I have Grass installed on windows (OsGeo4W) Grass 6.4 svn and the
v.edit command only returns 2 polygons. But I can see the 3
overlapping polygons when I plot the vector file using layer 2...
Cheers
Daniel
On Tue, Sep 1, 2009 at 1:46 PM, Marc-Antoine
Nussli<marc-antoine.nuessli at euratlas.com> wrote:
> Ok, so it is definitively related to the OS...
> I've just tested it right now on GNU/Linux and everything work correctly.
> Then, I've tested it again on Windows(but on a different computer than this
> afternoon) and it didn't work.
> So, to summarize:
> Grass 6.3 Release - Win32 (precompiled binaries) - computer A : BAD
> Grass 6.4RC5 - Win32 (compiled by myself) - computer A: BAD
> Grass 6.4RC5 - Win32 (compiled by myself) - computer B: BAD
> Grass 6.4RC5 - Linux (compiled by myself) - computer B: OK
> Maybe someone else who works on Windows can confirm the problem?!?
> MA
>>    > I have tested with Grass 6.3 AND grass 6.4(the one on which I'm
>>    working on)
>>    6.4 from SVN (revision?) or RC?
>> 6.4RC5
>> What about you?
>> I guess I should try with the latest SVN...
>>    > Did you use any special parameter during the import (apart from
>>    setting the
>>    > format to standard) ?
>>    I used the ASCII vector map you have attached (v.in.ascii
>>    format=standard)
>> Ok, so that's not related to that.
>>    > The only other possibility that I can see is the OS. I'm
>>    currently testing
>>    > on windows.
>>    I don't think so.
>> Yes, that would be very strange...
>>    > Are you also on windows or on Linux?!?
>>    GNU/Linux
>>    > Have you also tried to select from layer 2 ? (v.edit map=test
>>    layer=2
>>    > tool=select cats=2 type=centroid --q)
>>    24,26,29
>>    Seems to be reasonable.
>> yes indeed...
>> ma
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
