[GRASS-user] display image (photo / jpeg) with PNG driver (i.e.
add logo to map).
Tim Holland
timothyholland at gmail.com
Thu Sep 3 02:31:48 EDT 2009
hamish-2 wrote:
> Tim Holland wrote:
>> I am getting an error message with r.in.gdal, though:
>> >WARNING: G_set_window(): Illegal latitude for North
> if earlier ver, use gdal_translate to convert to geotiff and
> assign dummy lat/lon coords to it. then fix it with r.region
> once it is inside.
Thanks for the help, Hamish. I think I am getting closer, but still running
into a bit of a hurdle.
What I have done is the following:
>gdal_translate -of GTiff -a_ullr 101 16 103 14 -expand rgb
/usr/Documents/logo.tif logo.tif
This proceeds, and generates the logo.tif group (you are right - it does
import with separate bands: logo.red, logo.green, logo.blue). However, it
gives the error message
>Error : band 1 has no color table
When I do r.in.gdal,
>r.in.gdal -o input=/usr/logo.tif output=logo
it does import the file successfully (as opposed to before giving that
"illegal north latitude" error), so that is a step forward. But (as error
above would suggest), all the bands are either <null> or 0's.
Any ideas?
Thanks again,
Tim
View this message in context: http://n2.nabble.com/display-image-photo-jpeg-with-PNG-driver-i-e-add-logo-to-map-tp3565214p3571467.html
Sent from the Grass - Users mailing list archive at Nabble.com.
