[GRASS-user] clear sky index interpolation
buraq zakkey at gmail.com
Fri Sep 4 09:49:59 EDT 2009
buraq wrote:
> Hi,
> It's a newbie question.
> I am trying to intepolate clear sky index values. First I put the values
> in a csv file in this format "lat,lon,kc".
> Then I used db.in.ogr to get table. Next step, vector raster map is
> created by v.in.db. When I want to create raster file, I use that command
> v.vol.rst input=Kc vect cellinp=elevationRaster wcolumn=indexValueColumn
> then I get this "Vector is not 3D"
> Should I add elevation to csv? or what is the right way the interpolate
> the data?
> Thanks
> Regards
hi again I tried interpolation with elevation data.  Now I got x,y and z But
now the problem is, v.vol.rst gives the "Error in COGRR!" "Interp_call
failed" message. Have you ever meet this kind of a error message? I searched
the list but couldn't find any information about that kind of problem.
Thanks
Regards
View this message in context: http://n2.nabble.com/clear-sky-index-interpolation-tp3572894p3580073.html
Sent from the Grass - Users mailing list archive at Nabble.com.
