[GRASS-user] gdal_translate and HDF4 problem on 64-bit ubuntu 9.04
server edition
Tveraa, Torkild
Torkild.Tveraa at nina.no
Tue Sep 8 07:57:25 EDT 2009
Thanks to Jose I learnt how to use gdal_translate to read HDF4 files,
but it then appeared that there is problems related 64-bit systems that
prevent me from doing what I want. From the internet I see that it is
recommended that HDF4 and gdal should be built from source. I tried to
do so and it seems to me that I was successful in building GDAL 1.6.2
with HDF4 support (see below). Anyway, when I try gdal_translate I get
the same error messages as has previously been reported on 64-bit
systems. Is there any simple solution to this as well?
Torkild
gdal_translate -of GTiff
'HDF4_EOS:EOS_GRID:"MOD13Q1.A2006129.h18v01.005.2008321145449.hdf":MODIS
_Grid_16DAY_250m_500m_VI:250m 16 days EVI' output=output.tif
Input file size is 4800, 4800
0ERROR 1: GDreadfield() failed for block.
ERROR 1: IReadBlock failed at X offset 0, Y offset 0
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 0
GDAL 1.6.2, released 2009/07/31
The following format drivers are configured and support output:
VRT: Virtual Raster
GTiff: GeoTIFF
NITF: National Imagery Transmission Format
HFA: Erdas Imagine Images (.img)
ELAS: ELAS
AAIGrid: Arc/Info ASCII Grid
DTED: DTED Elevation Raster
PNG: Portable Network Graphics
JPEG: JPEG JFIF
MEM: In Memory Raster
GIF: Graphics Interchange Format (.gif)
XPM: X11 PixMap Format
BMP: MS Windows Device Independent Bitmap
PCIDSK: PCIDSK Database File
PCRaster: PCRaster Raster File
ILWIS: ILWIS Raster Map
SGI: SGI Image File Format 1.0
SRTMHGT: SRTMHGT File Format
Leveller: Leveller heightfield
Terragen: Terragen heightfield
GMT: GMT NetCDF Grid Format
netCDF: Network Common Data Format
HDF4Image: HDF4 Dataset
ERS: ERMapper .ers Labelled
JPEG2000: JPEG-2000 part 1 (ISO/IEC 15444-1)
FIT: FIT Image
RMF: Raster Matrix Format
RST: Idrisi Raster A.1
INGR: Intergraph Raster
GSAG: Golden Software ASCII Grid (.grd)
GSBG: Golden Software Binary Grid (.grd)
PNM: Portable Pixmap Format (netpbm)
ENVI: ENVI .hdr Labelled
EHdr: ESRI .hdr Labelled
PAux: PCI .aux Labelled
MFF: Vexcel MFF Raster
MFF2: Vexcel MFF2 (HKV) Raster
BT: VTP .bt (Binary Terrain) 1.3 Format
IDA: Image Data and Analysis
USGSDEM: USGS Optional ASCII DEM (and CDED)
ADRG: ARC Digitized Raster Graphics
BLX: Magellan topo (.blx)
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090908/e3415310/attachment-0001.html
