[GRASS-user] Problem GRASS 6.4 RC5-3 freezing on Leopard; Snow
	Leopard
    Kurt Springs
    ferret_bard at mac.com
    Mon Sep 14 19:31:10 EDT 2009
I am not sure which python I am using.  Looking in spotlight there is
MacPython 2.3 in the developer tools.  I thought 2.5 was supposed to
come with the install. I never updated it.
Kurt
On Sep 14, 2009, at 5:45 PM, William Kyngesburye wrote:
> On Sep 11, 2009, at 10:38 AM, Kurt Springs wrote:
>> I am having a problem with GRASS on OS 10.5.8.  When I launch a
>> project, GRASS freezes when I resize the Map window by dragging the
>> corner (which I have done in the past) it freezes.  I can resize
>> using the green resize but on the window (the one next to the red
>> close window button and the amber put window in dock button) and it
>> works fine.  But the moment I try to resize by using the corner, it
>> refreshes a few times but freezes.  I can't access menus or
>> scroll.  Interesting point, in the GIS Manager window, the Map
>> Layers for Display 1 portion of the window runs into the bottom
>> portion were the layer is chosen and set up. You can see the layer
>> icon and the check box, but not the text describing the layer.  It
>> is like this before it freezes.
> Working for me.  Have you updated anything since the last time it
> worked?  Which Python are you using?
>> As a point of interest, I have installed Snow leopard on my lap
>> top.  GRASS froze when I tried to resize it first, but when I
>> opened my map file first, populating the Map Layers, it worked
>> fine.  I did get an error code when I started up:
>> Last login: Fri Sep 11 10:38:37 on ttys000
>> kurt-springss-macbook-pro:~ kurtsprings2$ '/Applications/
>> GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
>> Rebuilding Addon HTML manual pages index...
>> Rebuilding Addon menu...
>> 2009-09-11 11:12:11.503 osascript[633:903] Error loading /Library/
>> ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit
>> Types:  dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/
>> Contents/MacOS/Adobe Unit Types, 262): no suitable image found.
>> Did find:
>> 	/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/
>> Adobe Unit Types: no matching architecture in universal wrapper
>> osascript: OpenScripting.framework - scripting addition "/Library/
>> ScriptingAdditions/Adobe Unit Types.osax" declares no loadable
>> handlers.
> This part is expected - all the old Applescript additions are 32bit,
> which won't load in 64bit apps.
>> Warning: No Python 2.5 found, needed by wxPython.
>>         The wxPython GUI may not work properly.
>> Cleaning up temporary files ...
>> This was from my lap top running 10.6.1.
> The Python detection on startup is broken for Snow, because it's
> expecting 2.5 but finding 2.6.  It will still try to run the GUI in
> 2.6, which may work, except that the wxnvzi and vdigit probably
> won't because they are built explicitly for 2.5.  The other problem,
> even if you do force GRASS to use Python 2.5, is that even the
> system 2.5 executable is now 64bit, while wxpython is 32bit.
> I'm surprised the GUI ran for you at all - besides the 64bit
> problem, I've had a problem with the reexec function that restarts
> with pythonw (needed by wxpython), it fails quietly, no GUI.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> The equator is so long, it could encircle the earth completely once.
