[GRASS-user] Problem with Grass 6.4 and R 2.9.2 on Ubuntu 9.04
Jarek Jasiewicz
jarekj at amu.edu.pl
Tue Sep 15 11:31:15 EDT 2009
you need to recompile gdal-grass plugin
Leonardo Hardtke pisze:
> Hi,
> I'm doing my first steps with the R-Grass interface but...
> library(spgrass6)
> Loading required package: sp
> Loading required package: rgdal
> Geospatial Data Abstraction Library extensions to R successfully loaded
> Loaded GDAL runtime: GDAL 1.6.1, released 2009/05/11
> Path to GDAL shared files: /usr/share/gdal16
> Loaded PROJ.4 runtime: Rel. 4.6.1, 21 August 2008
> Path to PROJ.4 shared files: (autodetected)
> Loading required package: XML
> GRASS GIS interface loaded with GRASS version: 6.4.0RC5
> and location: monte
> > a=readVECT6("area_estudio")
> ERROR: Incompatible library version for module. You need to rebuild GRASS
> or untangle multiple installations.
> I installed grass65 from source, is this the problem? How do I fix it?
> Thanks!
> Lic. Leonardo A. Hardtke
> Laboratorio de Teledetección y S.I.G.
> Centro Nacional Patagónico (CONICET)
> Bvd. Brown 2825, 9120 Puerto Madryn, Chubut, Argentina
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
