[GRASS-user] Problem with v.generalize to simplify areas
Marc-Antoine Nussli marc-antoine.nuessli at euratlas.com
Wed Sep 16 15:18:46 EDT 2009
I'm trying to simplify a vector map of areas describing countries.
I tried to use v.generalize with the various proposed simplification
method but the result is completely wrong as soon as I set a high
threshold value(actually, it works only with very low values) The
resulting map is always completely broken with most of the areas having
disappeared.
I have attached a sample file(in grass standard ascii format). If you
run v.generalize with a threshold of 100, the map will be broken but
with a value of 10, it works. Note that a threshold of 100 is still very
low considering the resolution of the map...
I know that there has been a few posts on this topic but I could not
find a answer which corrects the problem.
Interestingly, I tried instead to use v.clean with the "prune" tool and
the result is very good. It works with very high threshold (at least up
to 10000) but I don't know if I can trust it as it is written in the
documentation that "The /prune/ tool is currently broken, please use
/v.generalize
<http://grass.osgeo.org/grass64/manuals/html64_user/v.generalize.html>/
instead." So, it is a bit contradictory with the results I got?
Do you know why v.generalize doesn't work with high threshold?
And do you know what is the actual status of the "prune" tool of v.clean?
I'm using grass 6.4RC5 on linux.
Thanks!
ma
ORGANIZATION:
DIGIT DATE:
DIGIT NAME:   nuessli
MAP NAME:     Output from v.overlay
MAP DATE:     Wed Sep 16 19:47:46 2009
MAP SCALE:    1
OTHER INFO:
ZONE:         0
MAP THRESH:   0.000000
VERTI:
B  31
 1393634      1744439
 1392830      1743576
 1392126      1742776
 1390096      1741654
 1389627      1739514
 1389143      1738990
 1387471      1738647
 1386608      1737845
 1384552      1735669
 1383144      1733369
 1379569      1730411
 1379245      1729420
 1380226      1729037
 1382312      1730226
 1383787      1731275
 1385013      1730935
 1385458      1731112
 1386990      1732503
 1389072      1734164
 1390954      1735371
 1393634      1737785
 1395326      1740621
 1395978      1740847
 1396993      1741999
 1397285      1742937
 1397216      1743844
 1396668      1744004
 1395620      1744150
 1395244      1744693
 1394651      1744934
 1393634      1744439
B  55
 1391536      1701442
 1392955      1702247
 1393745      1702931
 1393392      1704999
 1391883      1706636
 1386777      1708685
 1384606      1709510
 1383213      1709541
 1382526      1709952
 1381405      1710528
 1379021      1710542
 1378223      1710463
 1377486      1710776
 1376041      1710765
 1374245      1710082
 1373509      1710440
 1372889      1710536
 1371674      1709393
 1370334      1707492
 1368043      1706881
 1365852      1706613
 1365070      1705757
 1362010      1701015
 1361347      1700127
 1360652      1699662
 1359338      1698152
 1357356      1694602
 1355917      1691395
 1355646      1688900
 1356813      1689033
 1357557      1691369
 1358520      1691694
 1359588      1693459
 1361467      1695594
 1362537      1697357
 1363264      1697977
 1364723      1698273
 1366023      1698108
 1367047      1696290
 1368166      1696111
 1369558      1697648
 1371516      1699150
 1371798      1699770
 1372069      1700867
 1373074      1701648
 1374159      1701869
 1375159      1701567
 1376395      1701886
 1377988      1702266
 1379260      1702599
 1383156      1702786
 1385621      1702669
 1388208      1701934
 1390098      1701414
 1391536      1701442
B  11
 1362520      1719674
 1361890      1719148
 1361050      1718200
 1360104      1717148
 1359789      1716411
 1360840      1716832
 1362205      1718095
 1363255      1719148
 1363780      1720095
 1363255      1720411
 1362520      1719674
B  16
 1356123      1670622
 1356063      1669532
 1356184      1668017
 1357271      1666744
 1358683      1666025
 1359398      1665855
 1360411      1663902
 1361015      1663715
 1361077      1665047
 1360532      1666078
 1359747      1667290
 1359022      1667471
 1358720      1668501
 1358116      1669350
 1357210      1670561
 1356123      1670622
B  16
 1343188      1658577
 1343917      1656945
 1345095      1654469
 1345488      1650248
 1346778      1650698
 1346722      1651092
 1346554      1652105
 1346834      1653118
 1346554      1654244
 1346049      1655200
 1346105      1656157
 1345488      1657452
 1344702      1658465
 1344198      1658802
 1343580      1658971
 1343188      1658577
B  9
 1174048.65969813 1755591.3764124
 1179076      1748519
 1182041      1746894
 1183957      1741200
 1182095      1736860
 1183886      1732291
 1184001.68468833 1731976.4786989
 1184122.3007785 1731825.70858618
 1186204.69339367 1726689.14013542
B  13
 1248803      1673299
 1248606.09058298 1673089.16647756
 1247635      1672353
 1246491      1667673
 1246224      1664625
 1246866      1660748
 1250227      1658526
 1250676      1654241
 1252387      1649936
 1254756      1648969
 1256634      1642841
 1260975      1637174
 1263771.4589607 1636840.97530372
B  24
 1039893.83800222 1852006.73408191
 1039793.82592811 1851875.46823465
 1039989      1851769
 1047646      1854376
 1054018      1853994
 1056772      1847738
 1062083      1845001
 1069279.28044894 1845632.41925037
 1069385      1845700
 1069517.71136105 1845653.33976185
 1080284      1841868
 1082694.283023 1840955.29425617
 1089796.85982265 1838265.75009097
 1091621      1837575
 1092061.011881 1835548.66286504
 1092662      1832781
 1099085      1830034
 1100384.51104224 1827507.7322309
 1100548      1827268
 1102509      1823833
 1101982.6844539 1821795.33100984
 1101996      1821168
 1102055.34724587 1819812.60840861
 1102163      1817354
B  13
 1101385      1814639
 1101075      1814187
 1095832.12166055 1810838.31234115
 1095208      1810376
 1095682.02539 1804279.37641968
 1095814      1802582
 1096065.32491299 1802128.42067726
 1096372.72853569 1801573.63315011
 1099330      1797809
 1100266.8782705 1794545.6557867
 1100357.49819728 1794066.47474639
 1100406.31321921 1793773.58461478
 1100635.68109211 1793653.91442023
B  8
 1188205      1727165
 1191995      1722898
 1204805      1728245
 1207384      1732999
 1211411      1733105
 1215197.48692915 1733190.32325069
 1215336.64245631 1733344.75399252
B  21
 1263134.97713332 1689189.08939515
 1263022.93242848 1689164.19057185
 1260070      1689638
 1258427      1692436
 1256843.28549968 1692630.88315592
 1256371      1692689
 1252370.38375894 1689380.3059149
 1251926.68881227 1689013.34973687
 1251942.46824281 1688919.81166955
 1251856.10912007 1688858.40073783
 1250590.31699989 1687958.28189681
 1250718.61486022 1684558.38859807
 1250654.46593005 1681447.16548508
 1250365.79574431 1679779.2933008
 1250429.94467447 1678047.27218635
 1250814.83825546 1676860.5169783
 1250973.18848298 1675254.39324202
 1251007.20133168 1674909.40577665
 1248962.59206275 1673359.42390072
 1248865.69889219 1673285.97091361
 1248803      1673299
B  65
 1248803      1673299
 1242797.58799105 1674169.29313276
 1242634      1674193
 1239132      1676404
 1237891.10837566 1676610.86711712
 1235131      1676730
 1235048.5658025 1677631.5386406
 1234916.78033654 1678416.57646416
 1234696.68223637 1680790.49168739
 1233993.69681923 1682317.62751461
 1233105.47300605 1682963.60846965
 1232340.72037067 1683519.79220447
 1232214      1683678
 1232007.22160628 1684461.21773051
 1231723.3509144 1685536.43915506
 1230740.96683948 1689871.20888563
 1230559      1690790
 1230521.90223402 1690837.83145724
 1228468      1693486
 1224824      1694365
 1224382.25442993 1692876.03373904
 1224296.45307017 1692084.20976184
 1224381.15006703 1689930.56572967
 1224709.94750484 1687516.90897374
 1225370      1684805
 1225293      1682810
 1225001.73026954 1681345.31534532
 1224699      1679823
 1221305.92410825 1679229.71168101
 1221136      1679200
 1219110      1685015
 1219090.96389967 1685604.99048808
 1218184      1689464
 1215694.18986568 1690700.69174438
 1215378      1690807
 1204763      1683755
 1204466.01140279 1683696.7139035
 1197933.80917462 1682414.72337264
 1197139.02587368 1682258.74157196
 1193182.08327139 1678630.91127825
 1191661      1677122
 1189827      1671653
 1183633      1670359
 1179044      1670457
 1177847      1677153
 1181180      1685170
 1180688.15023551 1690227.01182816
 1180624.95337473 1690876.77786554
 1180882.42716864 1691661.32517164
 1182052.30099134 1693222.8291391
 1184044      1695049
 1184748.7636022 1697018.12926027
 1185685      1699634
 1186128.22536907 1699902.3702238
 1186114.53507776 1701120.34328797
 1186047.40891733 1702073.53476614
 1182315      1705890
 1183108      1710245
 1181603      1717115
 1180105      1719658
 1180483      1721998
 1183288      1724497
 1184678.2334023 1725692.85426398
 1185695.68849473 1726568.0511976
B  10
 1093819.06975297 1747003.80614851
 1087100      1749283
 1085380      1751022
 1083077      1751342
 1080614      1752784
 1080562      1753253
 1080181      1756712
 1082713      1757372
 1085036      1757550
 1085903.21618419 1758353.16567962
B  22
 1139912.72868166 1752190.09493519
 1139106      1747412
 1139979      1737469
 1136389      1731057
 1134041      1726545
 1128372      1725400
 1124058      1722921
 1119486      1727701
 1116203      1729953
 1113316      1734532
 1110732      1736391
 1109626      1738275
 1109416      1738194
 1107761      1740782
 1104690      1744301
 1102911      1743724
 1103587      1740500
 1102859      1737059
 1100217      1737405
 1098453      1743915
 1095661      1746379
B  10
 1192229.73886312 1850371.92685658
 1193485.70450058 1852883.85813151
 1194462.56666306 1855814.44461893
 1196416.290988 1858047.27241886
 1196695.39446299 1859303.23805632
 1195578.98056302 1860838.30716878
 1194462.56666306 1860419.65195629
 1192927.4975506 1860280.1002188
 1192274.50074119 1859545.4788082
 1188444.87299721 1858056.17912999
B  25
 1344744      1813794
 1345331      1810097
 1343288      1810003
 1340342      1808824
 1341812      1806016
 1342493      1804255
 1340815      1801624
 1338240      1800615
 1337267      1799457
 1337171      1797414
 1338608      1796446
 1338413      1792821
 1337538      1790400
 1332012      1788996
 1330337      1790879
 1329238      1789151
 1326234      1789048
 1324287      1787318
 1324091      1783572
 1325358      1784109
 1326943      1783542
 1327366      1780866
 1326327      1778527
 1321942      1780101
 1320412      1778985
B  16
 1250597.85790706 1895482.34527482
 1247652      1893440
 1245930      1890900
 1243917      1888557
 1242042      1883947
 1240875      1877806
 1237362.88902591 1876993.96575187
 1236778.71524907 1877432.0960845
 1235677.37748081 1877365.34834097
 1234735.70981486 1876652.73497214
 1234442.54422548 1876430.87993153
 1233879.16471685 1876571.72480869
 1232173.12094542 1876998.23575155
 1230471.05348538 1876464.2538033
 1229536.58507594 1876330.75831624
 1229431.41920896 1876278.17538275
B  34
 1228619      1876244
 1224322      1871415
 1222554      1867250
 1221325      1863185
 1218404      1861980
 1218814      1859016
 1222143      1856048
 1224035      1852083
 1227083      1845795
 1224735      1843093
 1225783      1840601
 1228475      1841528
 1231903      1843408
 1238663      1847268
 1242422      1849100
 1243606      1853791
 1246170      1858763
 1249181      1862360
 1252713      1864568
 1254851      1870733
 1256423      1875277
 1257861      1880381
 1261521      1886102
 1263810.99031574 1891557.54470823
 1265149.78787667 1894067.79013497
 1266048.30558185 1897362.35505396
 1262693.83948252 1901735.14121916
 1258560.6580387 1904011.38607228
 1255505.6978411 1903112.8683671
 1250833.40577418 1902094.54830123
 1250653.70223314 1899518.79754639
 1250054.69042969 1896883.1456112
B  16
 1208132.67906191 1840089.32400743
 1208138.63693766 1840184.65001938
 1210790.11995008 1839626.4430694
 1212743.84427502 1839486.8913319
 1214418.46512498 1839626.4430694
 1215657.6065056 1839340.48736618
 1215241      1839253
 1215307.17858471 1838392.67839874
 1215463.53188665 1838364.25052566
 1216620.38403693 1837593.01575881
 1217329.51406305 1837461.6953836
 1217458.01757205 1837382.61630114
 1219270.00420196 1836947.73950996
 1221565.62973574 1835537.73600952
 1224747.51016412 1833583.38305604
 1225104.19090322 1832619.38105849
B  18
 1225768.88058999 1830822.92244559
 1227555.77464219 1829690.73922506
 1227712.09460956 1828179.64620713
 1227972.84362408 1825659.07240012
 1229257.11001566 1824392.16095978
 1230030.38393474 1823629.33668825
 1229946.97013836 1822739.58952688
 1229360.37475846 1820520.72874202
 1229307.46436613 1820320.58943191
 1229376.53121366 1820278.38191398
 1230308.42992267 1819708.88825847
 1229631.40272181 1817452.13092227
 1229474.29195889 1816928.4283792
 1229804.75232327 1816758.73251641
 1230503.06211422 1816400.14100214
 1230920.13109611 1814926.49726613
 1230530.86671301 1813953.33630838
B  11
 1205713.60182551 1791108.63061141
 1209541      1796426
 1215882      1800534
 1221810      1802014
 1222856      1807481
 1228106      1809027
 1228446      1811649
 1229168.30902985 1812354.66451742
 1229029.4183782 1812451.88797357
 1229140.63677337 1812924.56615305
B  27
 1230564.71286467 1813718.89035083
 1230746      1813896
 1239816      1815406
 1248567      1814186
 1251100      1812698
 1251018.3817095 1810230.41777056
 1250847      1805049
 1254827      1804006
 1257125      1805774
 1260177      1809719
 1263214      1812857
 1267159      1813180
 1269538      1811313
 1272807      1812474
 1274009      1815637
 1278531      1816428
 1281174      1815215
 1286475      1815064
 1287768      1812317
 1290070      1808636
 1290734      1801413
 1300702      1789598
 1311827      1780171
 1315317      1779609
 1318379      1780874
 1320412      1778985
B  78
 1320412      1778985
 1323148      1775382
 1325142      1773848
 1325611      1771920
 1323326      1768674
 1322107      1764871
 1320140      1763108
 1318655      1762116
 1316420      1763394
 1314105      1762324
 1312533      1760866
 1313688      1758927
 1315433      1757640
 1316220      1752842
 1317438      1750978
 1311464      1748851
 1308656      1746805
 1310690      1744133
 1313183      1744022
 1314951      1743023
 1315183      1740703
 1315116      1740159
 1317696      1739773
 1318979      1737785
 1323091      1738139
 1326177      1736272
 1324980      1731929
 1323062      1731062
 1322210      1728770
 1325183      1724860
 1325993      1721970
 1326746      1717041
 1325656      1710445
 1324112      1710504
 1323994      1708414
 1325607      1706913
 1324797      1704718
 1321876      1703506
 1318453      1704244
 1314784      1705799
 1310369      1704690
 1304633      1706092
 1300276      1706747
 1299957      1702827
 1298994      1696514
 1299140      1695186
 1298627      1694008
 1298652      1692406
 1296734      1687383
 1294595      1685323
 1291680      1684414
 1287423      1685808
 1285429      1685315
 1283995      1683173
 1284172      1679619
 1283409      1677545
 1281893      1676723
 1277530      1675492
 1274974      1674216
 1273778      1674753
 1272427      1675807
 1270136      1675619
 1269747      1675042
 1268142      1674271
 1267112      1673596
 1265676      1673928
 1263680      1675489
 1263053      1676539
 1262578      1677184
 1263352      1678575
 1263435.70893557 1679305.0569381
 1263635.70407242 1680351.69815427
 1263793.82836898 1682899.25626546
 1263468.79509272 1686430.69888855
 1263413.83270576 1686721.21436247
 1263333.97529425 1687706.11581306
 1263275.5320636 1688495.09942693
B  67
 1262757.23575822 1691086.58095382
 1262347.456679 1692189.83232095
 1261985.28236112 1693164.91702293
 1261913.46825553 1693201.92602929
 1260413.92021698 1693994.31769897
 1260392.58991611 1694043.05819643
 1260235.30401263 1694402.46208991
 1260045.37531365 1695069.52873999
 1260182.1219414 1695527.37029747
 1260299.21676863 1696279.57728547
 1259945      1701232
 1259901      1702660
 1259235      1704080
 1259019      1708131
 1258253      1708881
 1256778.22004119 1709329.13755655
 1256443      1709431
 1256385.14184464 1709435.24455439
 1255502.53879695 1709011.5950915
 1255239.26800305 1708963.36623299
 1254466.94223583 1709193.32839964
 1253268.47941371 1709441.92595097
 1252846.92130562 1709529.3698929
 1252801.49866819 1709853.52235094
 1252736.57932276 1710316.81040696
 1252460.7243656 1711049.07992959
 1252416      1711104
 1251887      1711389
 1250804      1711233
 1249333.59243466 1712074.79154568
 1249052      1712236
 1247328      1712289
 1246263      1712456
 1246237.63293963 1712505.06279172
 1245784.22751328 1713382.00066612
 1245623.43295526 1713692.9957044
 1245332.35006099 1715596.23001305
 1245044.43823739 1717073.3428472
 1244714      1717130
 1240101      1718474
 1239397.05027484 1717986.11808065
 1236818      1715363
 1236594.92359379 1715403.28871037
 1234570      1715769
 1233818      1717507
 1233707.60140344 1717593.44185413
 1232030      1718907
 1229928.19318004 1717475.91567066
 1229357      1717087
 1227715      1717715
 1227575.80322283 1718021.64231206
 1227282.93788475 1718666.80742449
 1224268.13995612 1719275.01160818
 1223841.53199419 1719284.57286005
 1222153.845956 1718389.14454691
 1221968.23577636 1718275.34755311
 1220241.30972087 1720185.4500703
 1218951.77705059 1721490.70874876
 1218633.41415919 1721854.63375455
 1216134.71613398 1723288.58671484
 1216010.56620258 1723349.14765699
 1215336.64245631 1728646.93710688
 1215393.82740732 1730219.52325979
 1215336.64245631 1730664.23086139
 1215336.64245631 1731094.99289929
B  15
 1216693      1734850
 1216721.93015699 1735085.41743859
 1216721.93015699 1737014.82362314
 1215935.68578633 1738156.749971
 1216933.13300838 1740312.5229993
 1217051.76000399 1740683.07291568
 1216796.81057324 1740833.72485204
 1216395.03163973 1745253.29312067
 1215300.88355966 1748629.52148201
 1214142.3917684 1756780.33872765
 1212739.46226829 1760255.77771656
 1209491      1763109
 1208062      1764382
 1207765.40732177 1764325.21945594
B  13
 1185531.91702318 1894412.54120596
 1191528.6598119 1887598.06076424
 1194932.73050697 1881640.93704786
 1197485.78352828 1873981.77798394
 1195783.74818074 1870861.37984678
 1191244.98725398 1866322.61892002
 1188813.84084426 1862432.78466447
 1188277.50635508 1862143.9891703
 1187699.08027994 1861437.02396735
 1186799.30638528 1859894.55443364
 1187313.46289651 1858673.43271946
 1188213.23679117 1858287.81533603
B  8
 1184833.49677584 1856651.7550439
 1182321.56550091 1853302.513344
 1183298.42766338 1850092.82338159
 1185391.70372582 1847720.44384416
 1188322.29021324 1848836.85774413
 1189996.91106319 1848418.20253164
B  32
 1192187.36495631 1850171.70728057
 1192069.41062544 1849611.42420893
 1192647.83670058 1849547.15464503
 1192926.05825244 1849556.1295338
 1194640.19318162 1849611.42420893
 1195090.08012895 1849547.15464503
 1195800.7276851 1848066.63890305
 1195861.3148958 1847940.41554742
 1196825.35835437 1847619.0677279
 1198496.36701588 1848197.49380304
 1199234.4231423 1848789.52215719
 1200231.6452413 1849225.80682551
 1200938.61044425 1848775.91987818
 1201232.25586554 1847978.88230611
 1201838.38433891 1846333.67644981
 1202416.81041405 1845755.25037467
 1206015.9059927 1846462.21557762
 1206526.59047002 1845951.53110029
 1206722.87119565 1845755.25037467
 1206787.14075955 1844855.47648001
 1206404.10434491 1844236.72534866
 1205951.6364288 1843505.81563801
 1205758.82773708 1842348.96348773
 1205823.09730099 1841770.5374126
 1206208.71468441 1841706.26784869
 1206825.42973582 1842130.25944653
 1207659.73714353 1841574.05450806
 1207558.37552641 1841320.65046526
 1207172.75814298 1840613.68526232
 1207429.8363986 1840035.25918718
B  31
 1207999.08520016 1837951.82221945
 1206743.1195627 1836556.30484449
 1201988.39851541 1835993.82847775
 1198698.29814572 1838149.41147857
 1197117.66978131 1838270.99827584
 1196509.735795 1836204.02272237
 1195780.21501142 1834988.15474975
 1196023.38860595 1833893.87357439
 1195901.80180869 1832070.07161545
 1196496.49550909 1830940.15358469
 1196276.7392505 1830555.58013216
 1196416.290988 1827624.99364475
 1194602.11840055 1824275.75194484
 1196137.18751301 1818972.78592
 1196834.94620049 1818275.02723252
 1195299.87708803 1811576.54383271
 1192787.94581311 1809204.16429528
 1192229.73886312 1804319.85348293
 1193764.80797558 1803482.54305795
 1194741.67013805 1801668.3704705
 1193625.25623808 1800133.30135805
 1193346.15276309 1798179.5770331
 1194741.67013805 1795528.09402068
 1196276.7392505 1794272.12838322
 1197607.13111583 1792561.62455637
 1197676.09432349 1792630.58776403
 1200317.52004665 1792102.3026194
 1201374.09033591 1791750.11252298
 1202254.56557697 1790165.25708908
B  3
 1202631      1786826
 1202435.16445921 1786630.29957811
B  9
 1138392.16676295 1858441.29618889
 1139661.90989813 1859287.79161235
 1141495.74225129 1859837.94131829
 1144429.87401635 1861305.00720082
 1145896.93989888 1862221.9233774
 1145346.79019293 1864055.75573056
 1146263.70636951 1865706.2048484
 1146997.23931077 1866072.97131903
 1146362.60968743 1867818.20278322
B  17
 1161180.32956215 1874509.62606376
 1165702.329313 1870657.55220193
 1167902.92813679 1868640.33661346
 1169920.14372526 1865339.43837777
 1170837.05990184 1863322.2227893
 1167902.92813679 1863688.98925993
 1164602.0299011 1863688.98925993
 1163868.49695984 1862772.07308335
 1162401.43107731 1859471.17484766
 1159283.91607694 1855436.74367071
 1159467.29931225 1854153.0610235
 1157266.70048846 1852502.61190566
 1155066.10166467 1851402.31249376
 1154515.95195872 1852319.22867034
 1154332.56872341 1853969.67778818
 1153232.26931151 1853419.52808224
 1151564.36920289 1853223.30454005
B  3
 1145530.17342824 1870107.40249598
 1143047.08595274 1875073.577447
B  43
 1185390.08538708 1893419.71975325
 1185513.91510719 1892800.57115271
 1184678.41077643 1891900.79725805
 1183907.17600958 1891836.52769414
 1182750.3238593 1891707.98856633
 1180950.77606997 1891900.79725805
 1180040.52018679 1891770.76070331
 1178204.28115928 1890699.62127059
 1177737.29787475 1890036.97990482
 1176580.44572447 1889265.74513797
 1175552.132702 1888494.51037111
 1174508.30633652 1888076.97982492
 1174508.30633652 1887950.43526978
 1174073.9327322 1887787.54516816
 1174297.18997293 1885275.90120996
 1174331.01098782 1884895.41479246
 1173752.58491268 1884509.79740904
 1171888.76755945 1883674.29307828
 1171310.34148431 1883545.75395047
 1170731.91540917 1883610.02351438
 1169933.83354246 1883729.73579438
 1169510.79369499 1883802.83220609
 1169060.90674765 1883610.02351438
 1169060.90674765 1882710.24961971
 1169317.98500327 1882517.440928
 1169824.98023783 1882314.64283418
 1169960.68064232 1882260.36267238
 1170860.45453698 1881874.74528896
 1171181.8023565 1881424.85834163
 1171310.34148431 1880846.43226649
 1170346.29802574 1880653.62357477
 1169446.52413108 1879496.77142449
 1168932.36761985 1877825.76276298
 1168868.09805594 1876990.25843222
 1167646.97634176 1876925.98886832
 1167442.11263868 1877364.98251776
 1167318.80025543 1877192.3451812
 1166875.7415749 1878211.3801464
 1166868.37601758 1878483.90576736
 1165335.56284236 1875975.66602609
 1162218.04784199 1875242.13308483
B  7
 1159100.53284162 1873041.53426104
 1156716.55078252 1871024.31867256
 1155799.63460594 1869740.63602535
 1152131.96989962 1870474.16896662
 1146997.23931077 1868090.18690751
B  2
 1092514.53122608 1788645.02408592
 1092408.9973982 1788900.06416997
B  8
 1093303.52807786 1789163.11261659
 1094451.08595581 1789405.35541311
 1095660      1789880
 1096272.82091062 1790755.91126708
 1096820      1791538
 1098867      1793037
B  16
 1100699      1793676
 1107289      1789822
 1108120      1788938
 1111007      1789246
 1114813      1790294
 1117859      1790330
 1122513      1788443
 1128641      1788568
 1132453      1794802
 1130116      1799249
 1126554      1802806
 1122998      1806593
 1118578      1812792
 1110462      1813089
 1101385      1814639
B  3
 1101385      1814639
 1101498.7477137 1815035.94735565
 1102163      1817354
B  27
 1102163      1817354
 1103487      1817805
 1114852      1817537
 1119843      1819821
 1121129      1827665
 1124839      1829842
 1127604      1831814
 1131280      1832208
 1132585      1832498
 1134105      1833060
 1133312      1835169
 1131107      1835212
 1126902      1834334
 1124248      1833602
 1121740      1831797
 1115495      1832212
 1116041      1834009
 1116835      1834959
 1118198      1836245
 1116753      1837760
 1114807      1839183
 1115042      1840781
 1113323      1840740
 1111244      1841583
 1110208      1842977
 1111309      1844846
 1112409.75572778 1846713.61555147
B  5
 1140550      1856332
 1143354      1856675
 1146713      1856799
 1151114      1854787
B  30
 1152705      1849263
 1153535      1848321
 1152989      1841923
 1146116      1835452
 1144873      1834789
 1144726      1832174
 1150142      1825465
 1160912      1824769
 1159369      1817281
 1154867      1808325
 1152816      1805777
 1154767      1799958
 1158293      1793843
 1164874      1786851
 1166269      1782706
 1167985      1783488
 1170114      1782560
 1172446      1781542
 1174534      1782282
 1176393      1783327
 1178550      1784613
 1180448      1783449
 1182916      1783915
 1186465      1784105
 1195289      1784199
 1198557      1784617
 1199763      1787571
 1201695      1787371
B  13
 1203076      1785989
 1203992.48900706 1784313.12164631
 1204510      1783407
 1205946      1782451
 1207289      1780390
 1209345      1776145
 1209498      1775039
 1209194.93903468 1774961.68190432
 1209562      1773523
 1209414      1770327
 1207592      1765231
B  23
 1208053      1762823
 1208107      1758658
 1205283      1757829
 1204437      1761021
 1197209      1759143
 1196339      1762335
 1199266      1763705
 1197504      1766990
 1192781      1767021
 1192427      1769168
 1194015      1773108
 1191930      1774560
 1190484      1776755
 1188381      1777997
 1180619      1775481
 1178309      1771907
 1176029      1769623
 1171594      1770570
 1172689      1764192
 1177285      1761269
 1176347      1756819
B  17
 1173857      1755861
 1172581      1755370
 1170413      1753762
 1165089      1752133
 1160405      1757444
 1155894      1758328
 1151018      1758691
 1150677      1756359
 1148722      1755227
 1148036      1753456
 1144425      1756001
 1143001      1756315
 1141298      1754605
 1141240      1754543
 1139948      1752399
B  35
 1139167      1752316
 1138950      1752203
 1137495      1756700
 1137583      1758820
 1138729      1761062
 1139246      1763920
 1138127      1765768
 1134544      1767676
 1131232      1767896
 1130758      1771787
 1128834      1774010
 1126962      1774764
 1126748      1777496
 1126408      1781714
 1125421      1783922
 1123593      1783256
 1121814      1785749
 1118478      1786060
 1116349      1783915
 1113505      1780964
 1113325      1774902
 1113861      1772147
 1113797      1768314
 1113281      1764933
 1112482      1762645
 1111775      1758576
 1111885      1755482
 1109410.08448498 1752387.63976101
 1106842.20013375 1753133.15457266
 1102215.75867664 1752861.01095753
 1097317.1736044 1752316.72372728
 1092010.37310948 1754493.87264828
 1087928.21888261 1755990.66253146
B  11
 1086918      1759293
 1090366      1760484
 1092579      1761929
 1094946      1765212
 1096810      1766311
 1094720      1767790
 1094348      1774303
 1096211      1779354
 1094776      1782226
B  7
 1138604      1872640
 1137971      1870368
 1139522      1868242
 1136579      1863986
 1136371      1860417
B  2
 1140550      1856332
B  15
 1140550      1856332
 1139742      1856233
 1138359      1852368
 1132753      1851367
 1129552      1850742
 1130114      1847922
 1128881      1846470
 1126995      1845873
 1125289      1846369
 1122150      1846738
 1117919      1848850
 1117564      1847416
 1115499      1847929
 1112509      1846882
B  31
 1111566.34527089 1848400.43646525
 1109627.80936639 1850460.13086378
 1107028.12242508 1850385.85409403
 1106518      1851046
 1102099.36405226 1851299.48229082
 1101933.87730171 1851308.97570941
 1099813.97134986 1855548.78761309
 1096663.85050505 1857608.48201162
 1091090.55977961 1858093.11598775
 1088425.07291093 1857245.00652953
 1084548.00110193 1856760.3725534
 1081397.88025712 1854942.99514294
 1079217.02736455 1854579.51966084
 1077520.80844812 1853489.09321456
 1074976.48007346 1851792.87429812
 1070130.14031221 1851308.240322
 1064799.16657484 1852762.14225037
 1061649.04573003 1855064.15363697
 1058135.44940312 1856881.53104744
 1055591.12102847 1859547.01791612
 1052198.68319559 1862454.82177287
 1047110.02644628 1861727.87080869
 1044565.69807163 1861243.23683256
 1041900.21120294 1863060.61424303
 1038628.9318641 1860637.4443624
 1039961.67529844 1857366.16502356
 1040529.05166073 1855025.7375291
 1039598.19981635 1854094.88568472
 1040043.35518206 1852202.97538045
B  24
 1388274.35444507 1799853.92755568
 1385227      1802716
 1383028      1802593
 1379376      1803731
 1376946      1808426
 1370969      1806962
 1369120      1807744
 1369316      1810163
 1365257      1810679
 1364043      1809770
 1360809      1809196
 1359003      1808272
 1357042      1810018
 1358470      1812825
 1357397      1816584
 1360710      1819438
 1359883      1822809
 1356599      1824330
 1352018      1825262
 1349435      1824781
 1349356      1822186
 1350719      1820324
 1346022      1816280
 1344744      1813794
B  48
 1344744      1813794
 1341927      1814938
 1337747      1817358
 1334328      1820605
 1329647      1822534
 1326336      1823358
 1323933      1824776
 1322741      1827988
 1324149      1831347
 1321375      1832367
 1320405      1833742
 1322961      1835668
 1321658      1837352
 1318709      1837059
 1316780      1836935
 1313527      1839565
 1312382      1840970
 1311215      1843560
 1312507      1846224
 1311556      1848788
 1310357      1851082
 1306803      1851822
 1305200      1852663
 1304932      1854573
 1302712      1856698
 1302639      1858172
 1302329      1860672
 1303153      1864358
 1303655      1867320
 1303773      1876399
 1304438      1877539
 1304702      1878751
 1304389      1882428
 1303124      1883220
 1301675      1886093
 1298621      1889981
 1297729      1893975
 1291079      1892910
 1286267      1894987
 1283306      1897058
 1281202      1900118
 1280249      1903510
 1281171      1905292
 1284514      1905842
 1288935      1906538
 1290702      1909428
 1292842      1913218
 1292797.61266636 1914258
B  4
 1396770      1737743
 1396679      1736643
 1397721      1736566
 1398396      1736982.17954071
B  4
 1398396      1739699.60575296
 1398310      1739600
 1397410      1738734
 1396770      1737743
B  2
B  19
 1218365.75502364 1634337
 1217951.1105901 1636721.20549287
 1218952.95119369 1639011.1268725
 1218237.35076256 1641444.16833835
 1220527.27214218 1643304.7294593
 1223675.91403917 1643447.84954553
 1224677.75464276 1644449.69014912
 1224391.51447031 1645737.77092516
 1222817.19352181 1647598.33204611
 1224820.87472899 1650890.09402932
 1229114.47731579 1652750.65515027
 1232119.99912655 1651748.81454668
 1233121.83973014 1648313.93247724
 1237415.44231695 1646596.49144252
 1238703.52309299 1644449.69014912
 1238989.76326544 1641730.40851081
 1239276.00343789 1639583.60721741
 1239705.36369657 1636864.3255791
 1240584.43346322 1634337
B  3
 1261542.73790812 1634337
 1261602.73688927 1634431.28411324
B  2
B  2
B  9
 1266282      1636542
 1268088      1637684
 1268970      1640017
 1270246      1640552
 1271657      1640507
 1275205      1637653
 1277294      1636474
 1279474.96807379 1634337
B  3
 1398396      1634337
B  2
B  21
 1091931.44326082 1744981.34919263
 1091283.03325874 1741415.09418118
 1090838.81867167 1739194.02124587
 1088173.53114931 1737417.16289763
 1085799.7594497 1737916.90430807
 1084175.59986576 1737195.0556041
 1081510.31234339 1735862.41184292
 1079289.23940808 1737417.16289763
 1076401.84459218 1739194.02124587
 1074402.87895041 1741192.98688765
 1074180.77165688 1743858.27441002
 1071959.69872157 1746523.56193238
 1072626.02060216 1749410.95674828
 1073347.76797067 1750565.7525379
 1071539      1749892
 1067802      1750804
 1065026      1749498
 1051091      1745277
 1039141      1746210
 1028238      1748389.89080413
B  9
 1028238      1763005.6887221
 1031941      1764290
 1035887      1766114
 1036140      1767748
 1033687      1767449
 1033468      1770537
 1031856      1774030
 1028977      1775167
 1028238      1775240.96880819
B  2
B  2
B  26
 1028238      1808526.03429505
 1028614.7945507 1808075.70634945
 1030006      1806413
 1039387.06545894 1806364.59185261
 1044608      1806089
 1049830.04579475 1806878.41103594
 1051145.65022627 1806583.22632809
 1052662      1806243
 1055367.59790441 1804763.53989306
 1060149      1802149
 1061809.10651444 1802249.26778788
 1066424      1802528
 1067459.03318154 1803727.97333683
 1068727      1805198
 1071226.03863651 1803731.88485833
 1071398      1803631
 1075891      1791901
 1082388.88114832 1791757.23394916
 1082944.00163153 1791744.95187169
 1086484      1788096
 1087206.33826281 1788171.74428245
 1087462      1787930
 1089989.92971905 1788463.63126717
 1091443      1788616
 1091830.1298775 1788729.84060405
B  2
B  12
 1206685.27446722 1914258
 1205144.9425922 1912277.57330354
 1198904.1463179 1908306.15749262
 1197485.78352828 1906320.44958716
 1192947.02260151 1903200.05145
 1191812.33236982 1898944.96308116
 1191404.56595264 1898789.62349366
 1190912.55847516 1898199.21452068
 1188855.93243022 1897492.24931773
 1186349.41943795 1896399.66673136
 1185741.33246944 1895878.44932978
B  2
B  12
 1152864.60524241 1914258
 1154129      1911501
 1153761      1907877
 1152367      1898112
 1151377      1891302
 1146637      1886049
 1146348.88913172 1885805.03767099
 1146030.4684252 1885535.41001816
 1141103      1881363
 1142754      1877520
 1143214      1875165
B  2
B  8
 1036479.63672614 1854065.05638232
 1034820.54387771 1854861.42094957
 1033509.86052744 1854629.14795079
 1031517.90205429 1853489.30504671
 1030523.49340026 1852920.2823169
 1029906.0899106 1852916.58529002
 1028238      1852906.59672768
B  2
B  8
 1398396      1778145.09794802
 1396820      1779211
 1392708      1781772
 1389861      1784266
 1388470      1792758
 1388554      1796416
 1388648      1799503
B  2
B  7
 1388698      1800305
 1390517      1803517
 1390278      1810187
 1393096      1815518
 1397396      1815800
 1398396      1818088.37401738
B  3
 1398396      1914258
B  2
B  23
 1082859.96603099 1914258
 1086217      1912677
 1091667      1911938
 1102159      1913579
 1093133      1909464
 1087240      1908978
 1082866      1906908
 1082272      1905574
 1077021      1903341
 1068490      1901961
 1064368      1901977
 1063902      1900715
 1062773      1900585
 1063025      1902214
 1056063      1906683
 1052114      1907360
 1049047      1906954
 1040198      1907800
 1036105      1908978
 1034974      1910457
 1030517      1910349
 1028859      1909540
 1028238      1909357.50204082
B  2
B  3
 1028238      1914258
B  2
B  2
 1043152.76483317 1634337
B  3
 1028238      1642410.47964796
 1028462      1642702
 1028238      1642731.71990172
B  2
 1028238      1634337
 1028238      1640496.17730496
B  2
B  2
B  3
 1028238      1703510.80203785
 1028906      1702203
 1028238      1701550.34456355
B  4
 1028238      1694254.17929393
 1029743      1693656
 1029173      1693160
 1028238      1693074.30507745
B  4
 1028238      1691653.39649294
 1028902      1691035
 1028440      1689665
 1028238      1689760.33923304
B  3
 1028238      1676583.97802198
 1028330      1675712
 1028238      1675589.19642857
B  5
 1028238      1670488.42456439
 1028249      1670468
 1028786      1664676
 1028287      1662783
 1028238      1662724.87611276
B  4
 1028238      1653868.82197802
 1028636      1653501
 1028923      1652893
 1028238      1653440.26541555
B  8
 1028238      1647946.76620616
 1031767      1644189
 1032883      1643106
 1034474      1642734
 1038272      1640789
 1040197      1638699
 1041235      1637537
B  2
B  2
B  2
B  2
B  2
B  2
B  2
B  2
B  2
B  2
B  2
B  2
B  2
B  2
B  2
 1037300.0855615 1634337
B  2
 1028238      1634337
B  4
 1034416      1636235
 1029201      1640053
C  1 1
 1388554.80645575 1736719.45680043
 1     1
C  1 1
 1372748.1589221 1701741.23149427
 1     2
C  1 1
 1361793.71826188 1718364.64436001
 1     3
C  1 1
 1358553.74638718 1667231.21135364
 1     4
C  1 1
 1345330.87432742 1654697.28612598
 1     5
C  1 1
 1194474.13365214 1752015.18679308
 1     6
C  1 1
 1142452.47770021 1687549.39467133
 1     7
C  1 1
 1334371.04319384 1714182.44970161
 1     8
C  1 1
 1088078.98337032 1843029.74903755
 1     9
C  1 1
 1064363.97757989 1821854.48764664
 1     10
C  1 1
 1113045.34461353 1800825.30337608
 1     11
C  1 1
 1217960.98318551 1698783.0274969
 1     12
C  1 1
 1061153.18415941 1771147.64674437
 1     13
C  1 1
 1114822.38673893 1752857.43187619
 1     14
C  1 1
 1189581.68260345 1854384.29749703
 1     15
C  1 1
 1266420.69807351 1850019.96201804
 1     16
C  1 1
 1242389.20846662 1872410.20500802
 1     17
C  1 1
 1209663.47247727 1816746.24816385
 1     18
C  1 1
 1270058.07949703 1749194.31891788
 1     19
C  1 1
 1178829.38431704 1836391.73392592
 1     20
C  1 1
 1141411.70534898 1866436.63239405
 1     21
C  1 1
 1154985.79765807 1862575.32237891
 1     22
C  1 1
 1170168.33530596 1895920.78015069
 1     23
C  1 1
 1141922.26516582 1793541.67454113
 1     24
C  1 1
 1088493.46035312 1884054.29621084
 1     25
C  1 1
 1349315.41710829 1864036.66183511
 1     26
C  1 1
 1397717.35350743 1737946.64200982
 1     27
C  1 1
 1229046.36477431 1641519.48921079
 1     28
C  1 1
 1270466.31248401 1636173.04455818
 1     29
C  1 1
 1031114.54574247 1768765.13441955
 1     30
C  1 1
 1394578.56386727 1798230.20241134
 1     31
C  1 1
 1064230.4349179 1910189.73802647
 1     32
C  1 1
 1028310.6721063 1642601.1303131
 1     33
C  1 1
 1034462.67295445 1640032.65149595
 1     34
C  1 1
 1031710.01528308 1636365.62009211
 1     35
C  1 1
 1028421.91769707 1702500.44142129
 1     36
C  1 1
 1028811.98945445 1693611.67014154
 1     37
C  1 1
 1028450.51099858 1690671.12810189
 1     38
C  1 1
 1028261.4029653 1676080.13737371
 1     39
C  1 1
 1028379.46710508 1666592.56296994
 1     40
C  1 1
 1028544.48064838 1653369.20041958
 1     41
