[GRASS-user] Dsn error in Window$
Vincent Blanqué vincent.blanque at oriondata.cl
Wed Sep 16 20:09:38 EDT 2009
It's my first post here. I am quite happy to join the powerful world of
GRASS. My first good impression is with the 'v.drape' process.
With the 'v.out.ogr' command, I get an issue with the dsn parameter.
I tried various syntax for dsn "path & filename" but none works fine.
v.out.ogr -e --verbose input=hidro3D at PERMANENT dsn=C:/tmp/hidro3D.shp
v.out.ogr -e --verbose input=hidro3D at PERMANENT dsn="C:/tmp/hidro3D.shp"
ERROR 1: Failed to create directory "C:/tmp/hidro3D.shp"
for shapefile datastore.
v.out.ogr -e input=hidro3D at PERMANENT dsn=/c/tmp/hidro3D.shp
I am using GRASS 6.4.0svn (2009) - Revision: 37101 in Windows Vista
(very bad choice).
Do you know what happens ?
In Linux Ubuntu, everything is great.
see U,
Vincent
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090916/3f3852c9/vincent_blanque.vcf
