[GRASS-user] Dsn error in Window$
maning sambale
emmanuel.sambale at gmail.com
Thu Sep 17 01:25:56 EDT 2009
afaik,
it should be:
v.out.ogr -e input=hidro3D at PERMANENT dsn=C:/tmp/hidro3D
On 9/17/09, Vincent Blanqué <vincent.blanque at oriondata.cl> wrote:
> Hi,
> It's my first post here. I am quite happy to join the powerful world of
> GRASS. My first good impression is with the 'v.drape' process.
> With the 'v.out.ogr' command, I get an issue with the dsn parameter.
> I tried various syntax for dsn "path & filename" but none works fine.
> v.out.ogr -e --verbose input=hidro3D at PERMANENT dsn=C:/tmp/hidro3D.shp
> v.out.ogr -e --verbose input=hidro3D at PERMANENT dsn="C:/tmp/hidro3D.shp"
> ERROR 1: Failed to create directory "C:/tmp/hidro3D.shp"
> for shapefile datastore.
> v.out.ogr -e input=hidro3D at PERMANENT dsn=/c/tmp/hidro3D.shp
> I am using GRASS 6.4.0svn (2009) - Revision: 37101 in Windows Vista
> (very bad choice).
> Do you know what happens ?
> In Linux Ubuntu, everything is great.
> see U,
> Vincent
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
