[GRASS-user] Dsn error in Window$
kapo coulibaly kmcoulib at gmail.com
Thu Sep 17 07:00:04 EDT 2009
Or you can add a name for the output file this way:
 v.out.ogr -e input=hidro3D at PERMANENT dsn=C:/tmp/ olayer=hidro3D
2009/9/17 maning sambale <emmanuel.sambale at gmail.com>
> afaik,
> it should be:
>  v.out.ogr -e input=hidro3D at PERMANENT dsn=C:/tmp/hidro3D
> On 9/17/09, Vincent Blanqué <vincent.blanque at oriondata.cl> wrote:
> > Hi,
> > It's my first post here. I am quite happy to join the powerful world of
> > GRASS. My first good impression is with the 'v.drape' process.
> > With the 'v.out.ogr' command, I get an issue with the dsn parameter.
> > I tried various syntax for dsn "path & filename" but none works fine.
> > v.out.ogr -e --verbose input=hidro3D at PERMANENT dsn=C:/tmp/hidro3D.shp
> > v.out.ogr -e --verbose input=hidro3D at PERMANENT dsn="C:/tmp/hidro3D.shp"
> > ERROR 1: Failed to create directory "C:/tmp/hidro3D.shp"
> > for shapefile datastore.
> > v.out.ogr -e input=hidro3D at PERMANENT dsn=/c/tmp/hidro3D.shp
> > I am using GRASS 6.4.0svn (2009) - Revision: 37101 in Windows Vista
> > (very bad choice).
> > Do you know what happens ?
> > In Linux Ubuntu, everything is great.
> > see U,
> > Vincent
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090917/44ebd590/attachment.html
