[GRASS-user] Dsn error in Window$
Markus Metz
markus.metz.giswork at googlemail.com
Thu Sep 17 12:28:07 EDT 2009
Since this is windows, would
v.out.ogr -e input=hidro3D at PERMANENT dsn="C:\tmp\hidro3D" olayer=hidro3D
work? Note \ instead of / in the path name.
Markus M
Vincent Blanqué wrote:
> @emmanuel:
> v.out.ogr -e input=hidro3D at PERMANENT dsn=C:/tmp/hidro3D
> (Thu Sep 17 11:48:08 2009) Command finished (1 sec)
> But I get a Window$ bug: "v.out.ogr.exe" has stopped to work.
> @kapo:
> v.out.ogr -e input=hidro3D at PERMANENT dsn=C:/tmp/ olayer=hidro3D
> ERROR 1: Failed to create directory C:/tmp/
> for shapefile datastore.
> Thanks, both solutions does not work, I will get rid of Window$ !!!
> kapo coulibaly a écrit :
>> Or you can add a name for the output file this way:
>> 2009/9/17 maning sambale <emmanuel.sambale at gmail.com>
>>> afaik,
>>> it should be:
>>> On 9/17/09, Vincent Blanqué <vincent.blanque at oriondata.cl> wrote:
>>>> Hi,
>>>> It's my first post here. I am quite happy to join the powerful world of
>>>> GRASS. My first good impression is with the 'v.drape' process.
>>>> With the 'v.out.ogr' command, I get an issue with the dsn parameter.
>>>> I tried various syntax for dsn "path & filename" but none works fine.
>>>> v.out.ogr -e --verbose input=hidro3D at PERMANENT dsn=C:/tmp/hidro3D.shp
>>>> v.out.ogr -e --verbose input=hidro3D at PERMANENT dsn="C:/tmp/hidro3D.shp"
>>>> ERROR 1: Failed to create directory "C:/tmp/hidro3D.shp"
>>>> v.out.ogr -e input=hidro3D at PERMANENT dsn=/c/tmp/hidro3D.shp
>>>> I am using GRASS 6.4.0svn (2009) - Revision: 37101 in Windows Vista
>>>> (very bad choice).
>>>> Do you know what happens ?
>>>> In Linux Ubuntu, everything is great.
>>>> see U,
>>>> Vincent
>>> cheers,
>>> maning
>>> "Freedom is still the most radical idea of all" -N.Branden
>>> wiki: http://esambale.wikispaces.com/
>>> blog: http://epsg4253.wordpress.com/
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
