[GRASS-user] Dsn error in Window$
Vincent Blanqué vincent.blanque at oriondata.cl
Thu Sep 17 12:43:09 EDT 2009
Neither works... Windows Vista has always strange behaviour. I hate it
more and more every day. But not all the profesional software works well
 in Linux. So I will keep the double boot for a while.
Thx everybody for your help,
Markus Metz a écrit :
> Since this is windows, would
> v.out.ogr -e input=hidro3D at PERMANENT dsn="C:\tmp\hidro3D" olayer=hidro3D
> work? Note \ instead of / in the path name.
> Markus M
> Vincent Blanqué wrote:
>> @emmanuel:
>> v.out.ogr -e input=hidro3D at PERMANENT dsn=C:/tmp/hidro3D
>> (Thu Sep 17 11:48:08 2009) Command finished (1 sec)
>> But I get a Window$ bug: "v.out.ogr.exe" has stopped to work.
>> @kapo:
>> v.out.ogr -e input=hidro3D at PERMANENT dsn=C:/tmp/ olayer=hidro3D
>> ERROR 1: Failed to create directory C:/tmp/
>> for shapefile datastore.
>> Thanks, both solutions does not work, I will get rid of Window$ !!!
>> kapo coulibaly a écrit :
>>> Or you can add a name for the output file this way:
>>> 2009/9/17 maning sambale <emmanuel.sambale at gmail.com>
>>>> afaik,
>>>> it should be:
>>>> On 9/17/09, Vincent Blanqué <vincent.blanque at oriondata.cl> wrote:
>>>>> Hi,
>>>>> It's my first post here. I am quite happy to join the powerful
>>>>> world of
>>>>> GRASS. My first good impression is with the 'v.drape' process.
>>>>> With the 'v.out.ogr' command, I get an issue with the dsn parameter.
>>>>> I tried various syntax for dsn "path & filename" but none works fine.
>>>>> v.out.ogr -e --verbose input=hidro3D at PERMANENT dsn=C:/tmp/hidro3D.shp
>>>>> dsn="C:/tmp/hidro3D.shp"
>>>>> ERROR 1: Failed to create directory "C:/tmp/hidro3D.shp"
>>>>> v.out.ogr -e input=hidro3D at PERMANENT dsn=/c/tmp/hidro3D.shp
>>>>> I am using GRASS 6.4.0svn (2009) - Revision: 37101 in Windows Vista
>>>>> (very bad choice).
>>>>> Do you know what happens ?
>>>>> In Linux Ubuntu, everything is great.
>>>>> see U,
>>>>> Vincent
>>>> cheers,
>>>> maning
>>>> "Freedom is still the most radical idea of all" -N.Branden
>>>> wiki: http://esambale.wikispaces.com/
>>>> blog: http://epsg4253.wordpress.com/
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090917/f10816a7/vincent_blanque.vcf
