[GRASS-user] Help needed in identifying the DEM / DTED classes
used in grass
Jarek Jasiewicz
jarekj at amu.edu.pl
Sun Sep 20 15:11:44 EDT 2009
Grass do not load DTED directly. It uses GDAL to do that. Look into GDAL
(www.gdal.org) source code to solve your problem
Jarek
Anand V pisze:
> Hi Everybody,
> I am new to GRASS and i am trying to load the DTED data map in my
> visual c++ application. Actually i am trying to load dt2 data directly
> in my visual c++ application, i do not want to run GRASS as separate
> process with my application, In GRASS source code i need to identify
> the classes used to load a DEM or DTED data so i can directly try
> those with my visual c++ application.
> Anybody know the classes and header files used in GRASS to load the
> dted data
> I tried and i am not able to identify.
> Please give ur suggestions and help me out
> Thanks in advance
> ANAND V
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
