[GRASS-user] Incompatible library version for module
achim ak7 at jupiter.uni-freiburg.de
Mon Sep 21 09:31:39 EDT 2009
Hi Nikos,
that did it!
(reinstalled gdal-grass, make clean, make, make install)
Thanks a lot,
Achim
Nikos Alexandris schrieb:
> Hi Achim :-)
> Recompile the gdal-grass-plugin. That should be it [1][2].
> Gruesse, Nikos
> [1]
> http://n2.nabble.com/error-Incompatible-library-version-for-module-You-need-to-rebuild-GRASS-or-untangle-multiple-install-td3347116.html#a3347116
> [2]
> http://lists.osgeo.org/pipermail/grass-stats/2009-January/000897.html
