[GRASS-user] QGIS: Segmentation fault
Benedikt Ziegler benesmail at web.de
Mon Sep 21 12:19:06 EDT 2009
OK, that's the results:
benedikt at inspiron1525:~$ dpkg -l grass qgis 'libgdal*'
Gewünscht=Unbekannt/Installieren/R=Entfernen/P=Vollständig Löschen/Halten
| Status=Nicht/Installiert/Config/U=Entpackt/Fehlgeschl. Konfiguration/
         Halb installiert/Trigger erWartet/Trigger anhängig
|/ Fehler?=(kein)/Halten/R=Neuinst notw/X=beide (Status, Fehler:
GROSS=schlecht)
||/ Name                       Version                    Beschreibung
ii  grass                      6.2.3-2.1                  Geographic
Resources Analysis Support System
un  libgdal1                   <keine>                    (keine
Beschreibung vorhanden)
un  libgdal1-1.3.1             <keine>                    (keine
un  libgdal1-1.3.2             <keine>                    (keine
un  libgdal1-1.4.0-grass       <keine>                    (keine
ii  libgdal1-1.5.0             1.5.2-3ubuntu1             Geospatial
Data Abstraction Library
ii  libgdal1-1.5.0-grass       1.5.2-1                    GRASS
extension for the Geospatial Data Abstraction Library
ii  libgdal1-1.6.0             1.6.0-1                    Geospatial
un  libgdal1-1.6.0-grass       <keine>                    (keine
un  libgdal1c2                 <keine>                    (keine
un  libgdal1c2a                <keine>                    (keine
ii  qgis                       1.3.0-1~jaunty6            Geographic
Information System (GIS)
I've installed the newest QGIS packages allready. But I don't think the
error is connected with these version. I had the same before with
version 1.0xxx. I didn't use QGIS the last month, so I don't know how
long it won't work. But as in installed these version 1.0xxx it worked fine.
Benedikt
Hamish schrieb:
> some reports in,
> Jorge wrote:
>> I've started qgis without any problem and loaded some plugins.
>> See screenshot at with north arrow plugin and so on
>> http://img44.yfrog.com/i/screenshotkj.png/
> [on the UbuntuGIS mailing list, where this conversation should be
> continued, (as they made the package)   http://lists.osgeo.org , ...]
> Alan wrote:
>> I would tell him to install the lastest qgis package, which is probably
>> build against the right dependencies: qgis - 1.3.0-1~jaunty3
> András wrote:
>> I appologize to join to this discuss, but I have the same problem as
>>  Benedikt. Since I have been changed to linux mint(ubuntu 9.04) from SUSE
>>  11.1 I can not start qgis. (either 1.2 nor 1.3)
>> the Qgis is stopping with the same segmentation error immediatelly after
>>  the Python modules are loading into
>> ii  libgdal1-1.6.0 1.6.2-3~jaunty Geospatial Data Abstraction Library
>> ii  libgdal1-1.6.0 1.6.2-3~jaunty GRASS extension for the GDAL library
>> ii  libgdal1-dev   1.6.2-3~jaunty Geospatial Data Abstraction Library -
>>  Develo un  libgdal1c2     <nincs>        (nincs leírás)
>> un  libgdal1c2a    <nincs>        (nincs leírás)
>> ii  qgis           1.3.0-1~jaunty Geographic Information System (GIS)
> akkk, terminal just 1 character too narrow to show the full versions ...
> Benedikt wrote:
>> Thanks for your help. But I not really know what have to do next.
>>  Do I have to type this term in the Terminal??
> yes, to see what versions of the packages you have installed.
> pull the terminal wide enough so that the full version number shows.
> to follow Alan's advice, try upgrading and see if there are any
> new packages waiting in the UbuntuGIS repository.
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090921/23ae2864/attachment.html
