Benedikt wrote:
> benedikt at inspiron1525:~$ dpkg -l grass qgis 'libgdal*'
> ii grass 6.2.3-2.1
> Geographic Resources Analysis Support System
> ii libgdal1-1.5.0 1.5.2-3ubuntu1
> Geospatial Data Abstraction Library
> ii libgdal1-1.5.0-grass 1.5.2-1
> GRASS extension for the Geospatial Data Abstraction Library
> ii libgdal1-1.6.0 1.6.0-1
> ii qgis 1.3.0-1~jaunty6
> Geographic Information System (GIS)
where does 1.3.0-1~jaunty6 come from? AFAICT that doesn't
exist yet from UbuntuGIS. Are you using another source?
> I've installed the newest QGIS packages allready. But I
> don't think the error is connected with these version.
the latest from ubuntuGIS repo are:
libgdal1-1.6.0_1.6.2-3~jaunty1
grass_6.4.0~rc5-3~jaunty1
qgis_1.3.0-1~jaunty3
all three need to be updated & in sync. You can't use a latest
QGIS with an older GDAL library. The ABI will have changed and
the result will be a segfault.
as this is not a GRASS matter it should continue on the
UbuntuGIS mailing list: http://lists.osgeo.org
regards,
Hamish
