[GRASS-user] stream network extraction
Jarosław Jasiewicz
jarekj at amu.edu.pl
Wed Sep 23 04:47:39 EDT 2009
Markus Metz pisze:
> Hi all,
> in grass-addons is a new module for clean stream network extraction
> from flow accumulation. It can extract streams from accumulation maps
> generated with any method (D8, FD8, D-Inf, DEMON, etc) and any
> software, granted that exactly the same elevation map is provided that
> was used to calculate flow accumulation. In case of r.terraflow, that
> would be the flooded (filled) output elevation map, not the elevation
> map used as input for r.terraflow. For e.g. TAS flow accumulation as
> input, it must be the elevation map used within TAS to calculate flow
> accumulation.
> r.stream.extract output is available as raster and vector with unique
> stream IDs. The vector is a complete network with stream segments and
> points for stream heads, confluences and outlets. The raster output
> can be used as input for the r.stream.* modules of Jarek, also in
> grass-addons.
> Regards,
> Markus M
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Hi Markus, Hi all.
rest of r.stream* modules including new r.stream.stats for Hortonian
statistics are now available by grass addons page and by grass add-ons
svn repository. I actually move tutorial on r.stream* to grass wiki page.
Jarek
