[GRASS-user] Problem finding r.mask in Windows script
Markus Neteler
neteler at osgeo.org
Wed Sep 23 16:59:06 EDT 2009
Hi Ned,
On Wed, Sep 23, 2009 at 7:50 PM, Ned Horning <horning at amnh.org> wrote:
> Hi -
> I have a script that I am running on the Windows version of GRASS 6.4.0
> installed using OSGEO4W. The script seems to run okay but the I am getting a
> message that I can't figure out.
> Early in the script I have the command:
> r.mask -r maskcats=*
> I also tried: r.mask -r MASK
> In both cases when the script runs I get the following message:
> C:/OSGeo4W/apps/grass/grass-6.4.0svn/scripts/r.shrub.cloud.resample: r.mask:
> command not found
> The r.mask command works fine when I run it from the command window or using
> the menu. Can anyone shed light on why the message is popping up?
just a curiosity: are you sure to run this script in the GRASS
terminal?
Markus
