[GRASS-user] Re: r.stream.order problem making on mac os x
stephen sefick ssefick at gmail.com
Sun Sep 27 15:38:22 EDT 2009
They have compiled after a
make clean
make
make install
but I am getting a bus error
On Sun, Sep 27, 2009 at 1:31 PM, stephen sefick <ssefick at gmail.com> wrote:
> I put the r.stream.order sources into my raster folder in the grass
> sources.  I tried both the from Jarek's website and the svn
> grass-addons both threw this error message.  The old version compiled
> and worked fine on my mac 10.5.7.  Any help would be greatly
> appreciated.
> Stephen Sefick
> test -d OBJ.i386-apple-darwin9.8.0 || mkdir -p OBJ.i386-apple-darwin9.8.0
> gcc -I/Users/sefick/Grass_Source/grass-6.4.0RC5/dist.i386-apple-darwin9.8.0/include
>  -g -O2       -DPACKAGE=\""grassmods"\"
> -o OBJ.i386-apple-darwin9.8.0/io.o -c io.c
> io.c:1:27: error: grass/glocale.h: No such file or directory
> In file included from io.c:2:
> global.h:5:23: error: grass/gis.h: No such file or directory
> global.h:66: error: syntax error before ‘*’ token
> global.h:67: error: syntax error before ‘*’ token
> global.h:78: error: syntax error before ‘*’ token
> global.h:78: warning: data definition has no type or storage class
> global.h:79: error: syntax error before ‘*’ token
> global.h:79: warning: data definition has no type or storage class
> io.c: In function ‘open_raster’:
> io.c:9: error: storage size of ‘cellhd’ isn’t known
> io.c:11: warning: assignment makes pointer from integer without a cast
> io.c:17: error: ‘CELL_TYPE’ undeclared (first use in this function)
> io.c:17: error: (Each undeclared identifier is reported only once
> io.c:17: error: for each function it appears in.)
> io.c:27: error: invalid use of undefined type ‘struct Cell_head’
> io.c: In function ‘create_base_maps’:
> io.c:38: error: ‘CELL’ undeclared (first use in this function)
> io.c:38: error: ‘r_dirs’ undeclared (first use in this function)
> io.c:38: error: ‘r_streams’ undeclared (first use in this function)
> io.c:39: error: ‘DCELL’ undeclared (first use in this function)
> io.c:39: error: ‘r_accum’ undeclared (first use in this function)
> io.c:47: error: syntax error before ‘)’ token
> io.c:48: error: syntax error before ‘)’ token
> io.c:50: error: syntax error before ‘)’ token
> io.c:52: error: syntax error before ‘)’ token
> io.c:53: error: syntax error before ‘)’ token
> io.c:55: error: syntax error before ‘)’ token
> io.c:62: warning: assignment makes pointer from integer without a cast
> io.c:63: warning: assignment makes pointer from integer without a cast
> io.c:73: error: syntax error before ‘)’ token
> io.c: In function ‘stream_number’:
> io.c:120: error: ‘CELL’ undeclared (first use in this function)
> io.c:120: error: syntax error before ‘c_min’
> io.c:123: warning: assignment makes pointer from integer without a cast
> io.c:125: error: ‘c_min’ undeclared (first use in this function)
> io.c:125: error: ‘c_max’ undeclared (first use in this function)
> io.c: In function ‘write_maps’:
> io.c:132: error: ‘CELL’ undeclared (first use in this function)
> io.c:132: error: ‘strahler_buf’ undeclared (first use in this function)
> io.c:132: error: ‘shreeve_buf’ undeclared (first use in this function)
> io.c:132: error: ‘hack_buf’ undeclared (first use in this function)
> io.c:132: error: ‘horton_buf’ undeclared (first use in this function)
> io.c:134: error: storage size of ‘history’ isn’t known
> io.c:138: error: ‘CELL_TYPE’ undeclared (first use in this function)
> make: *** [OBJ.i386-apple-darwin9.8.0/io.o] Error 1
> Stephen Sefick
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods.  We are mammals, and have not exhausted the
> annoying little problems of being mammals.
>        -K. Mullis
Stephen Sefick
								-K. Mullis
