[GRASS-user] r.stream.order problem making on mac os x
stephen sefick ssefick at gmail.com
Sun Sep 27 14:31:01 EDT 2009
I put the r.stream.order sources into my raster folder in the grass
sources.  I tried both the from Jarek's website and the svn
grass-addons both threw this error message.  The old version compiled
and worked fine on my mac 10.5.7.  Any help would be greatly
appreciated.
Stephen Sefick
test -d OBJ.i386-apple-darwin9.8.0 || mkdir -p OBJ.i386-apple-darwin9.8.0
gcc -I/Users/sefick/Grass_Source/grass-6.4.0RC5/dist.i386-apple-darwin9.8.0/include
 -g -O2       -DPACKAGE=\""grassmods"\"
-o OBJ.i386-apple-darwin9.8.0/io.o -c io.c
io.c:1:27: error: grass/glocale.h: No such file or directory
In file included from io.c:2:
global.h:5:23: error: grass/gis.h: No such file or directory
global.h:66: error: syntax error before ‘*’ token
global.h:67: error: syntax error before ‘*’ token
global.h:78: error: syntax error before ‘*’ token
global.h:78: warning: data definition has no type or storage class
global.h:79: error: syntax error before ‘*’ token
global.h:79: warning: data definition has no type or storage class
io.c: In function ‘open_raster’:
io.c:9: error: storage size of ‘cellhd’ isn’t known
io.c:11: warning: assignment makes pointer from integer without a cast
io.c:17: error: ‘CELL_TYPE’ undeclared (first use in this function)
io.c:17: error: (Each undeclared identifier is reported only once
io.c:17: error: for each function it appears in.)
io.c:27: error: invalid use of undefined type ‘struct Cell_head’
io.c: In function ‘create_base_maps’:
io.c:38: error: ‘CELL’ undeclared (first use in this function)
io.c:38: error: ‘r_dirs’ undeclared (first use in this function)
io.c:38: error: ‘r_streams’ undeclared (first use in this function)
io.c:39: error: ‘DCELL’ undeclared (first use in this function)
io.c:39: error: ‘r_accum’ undeclared (first use in this function)
io.c:47: error: syntax error before ‘)’ token
io.c:48: error: syntax error before ‘)’ token
io.c:50: error: syntax error before ‘)’ token
io.c:52: error: syntax error before ‘)’ token
io.c:53: error: syntax error before ‘)’ token
io.c:55: error: syntax error before ‘)’ token
io.c:62: warning: assignment makes pointer from integer without a cast
io.c:63: warning: assignment makes pointer from integer without a cast
io.c:73: error: syntax error before ‘)’ token
io.c: In function ‘stream_number’:
io.c:120: error: ‘CELL’ undeclared (first use in this function)
io.c:120: error: syntax error before ‘c_min’
io.c:123: warning: assignment makes pointer from integer without a cast
io.c:125: error: ‘c_min’ undeclared (first use in this function)
io.c:125: error: ‘c_max’ undeclared (first use in this function)
io.c: In function ‘write_maps’:
io.c:132: error: ‘CELL’ undeclared (first use in this function)
io.c:132: error: ‘strahler_buf’ undeclared (first use in this function)
io.c:132: error: ‘shreeve_buf’ undeclared (first use in this function)
io.c:132: error: ‘hack_buf’ undeclared (first use in this function)
io.c:132: error: ‘horton_buf’ undeclared (first use in this function)
io.c:134: error: storage size of ‘history’ isn’t known
io.c:138: error: ‘CELL_TYPE’ undeclared (first use in this function)
make: *** [OBJ.i386-apple-darwin9.8.0/io.o] Error 1
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods.  We are mammals, and have not exhausted the
annoying little problems of being mammals.
								-K. Mullis
