[GRASS-user] Re: r.stream.order problem making on mac os x
Jarek Jasiewicz
jarekj at amu.edu.pl
Mon Sep 28 01:33:23 EDT 2009
well, r.stream.order is completely rewritten. Coud you tell me more
about your bus error?
stephen sefick pisze:
> OK,
> I got a clean source 6.4RC05 directory and copied the r.stream.*
> modules into the raster folder in the sources.
> I issued this from CL:
> ./configure --with-freetype
> --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2
> /Library/Frameworks/FreeType.framework/unix/include"
> --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib
> --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config
> --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include
> --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib
> --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
> --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include
> --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib
> --without-postgres --without-mysql --with-odbc --with-sqlite
> --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
> --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include
> --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include
> --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib
> --with-cxx --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers
> /Library/Frameworks/Tk.framework/Headers
> /Library/Frameworks/Tk.framework/PrivateHeaders"
> --with-tcltk-libs=/usr/local/lib --with-x --without-motif
> --without-glw --with-python
> --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.10.1/bin/wx-config
> --with-opengl=aqua --without-readline --prefix=/Applications
> --enable-macosx-app
> make
> sudo make install
> I am building a MacOSX .app and this works just fine. I can use GRASS
> and everything that I have tried has worked fine. The
> r.stream.extract function worked wonderfully and output raster maps
> from r.terraflow flow accumulation and direction map. I tried to feed
> this into r.stream.order. I got a bus error on the command line, and
> in the GUI it just stops. In both instances I get a ignore report mac
> GUI message. This is what I did with the previous ordering software -
> r.stream, and everything worked fine. If there is anymore information
> that I can provide please tell me and I will be happy to provide this.
> Thanks for all of the help
> Stephen Sefick
> On Sun, Sep 27, 2009 at 2:38 PM, stephen sefick <ssefick at gmail.com> wrote:
>> They have compiled after a
>> make clean
>> make
>> make install
>> but I am getting a bus error
>> On Sun, Sep 27, 2009 at 1:31 PM, stephen sefick <ssefick at gmail.com> wrote:
>>> I put the r.stream.order sources into my raster folder in the grass
>>> sources. I tried both the from Jarek's website and the svn
>>> grass-addons both threw this error message. The old version compiled
>>> and worked fine on my mac 10.5.7. Any help would be greatly
>>> appreciated.
>>> Stephen Sefick
>>> test -d OBJ.i386-apple-darwin9.8.0 || mkdir -p OBJ.i386-apple-darwin9.8.0
>>> gcc -I/Users/sefick/Grass_Source/grass-6.4.0RC5/dist.i386-apple-darwin9.8.0/include
>>> -g -O2 -DPACKAGE=\""grassmods"\"
>>> -o OBJ.i386-apple-darwin9.8.0/io.o -c io.c
>>> io.c:1:27: error: grass/glocale.h: No such file or directory
>>> In file included from io.c:2:
>>> global.h:5:23: error: grass/gis.h: No such file or directory
>>> global.h:66: error: syntax error before ‘*’ token
>>> global.h:67: error: syntax error before ‘*’ token
>>> global.h:78: error: syntax error before ‘*’ token
>>> global.h:78: warning: data definition has no type or storage class
>>> global.h:79: error: syntax error before ‘*’ token
>>> global.h:79: warning: data definition has no type or storage class
>>> io.c: In function ‘open_raster’:
>>> io.c:9: error: storage size of ‘cellhd’ isn’t known
>>> io.c:11: warning: assignment makes pointer from integer without a cast
>>> io.c:17: error: ‘CELL_TYPE’ undeclared (first use in this function)
>>> io.c:17: error: (Each undeclared identifier is reported only once
>>> io.c:17: error: for each function it appears in.)
>>> io.c:27: error: invalid use of undefined type ‘struct Cell_head’
>>> io.c: In function ‘create_base_maps’:
>>> io.c:38: error: ‘CELL’ undeclared (first use in this function)
>>> io.c:38: error: ‘r_dirs’ undeclared (first use in this function)
>>> io.c:38: error: ‘r_streams’ undeclared (first use in this function)
>>> io.c:39: error: ‘DCELL’ undeclared (first use in this function)
>>> io.c:39: error: ‘r_accum’ undeclared (first use in this function)
>>> io.c:47: error: syntax error before ‘)’ token
>>> io.c:48: error: syntax error before ‘)’ token
>>> io.c:50: error: syntax error before ‘)’ token
>>> io.c:52: error: syntax error before ‘)’ token
>>> io.c:53: error: syntax error before ‘)’ token
>>> io.c:55: error: syntax error before ‘)’ token
>>> io.c:62: warning: assignment makes pointer from integer without a cast
>>> io.c:63: warning: assignment makes pointer from integer without a cast
>>> io.c:73: error: syntax error before ‘)’ token
>>> io.c: In function ‘stream_number’:
>>> io.c:120: error: ‘CELL’ undeclared (first use in this function)
>>> io.c:120: error: syntax error before ‘c_min’
>>> io.c:123: warning: assignment makes pointer from integer without a cast
>>> io.c:125: error: ‘c_min’ undeclared (first use in this function)
>>> io.c:125: error: ‘c_max’ undeclared (first use in this function)
>>> io.c: In function ‘write_maps’:
>>> io.c:132: error: ‘CELL’ undeclared (first use in this function)
>>> io.c:132: error: ‘strahler_buf’ undeclared (first use in this function)
>>> io.c:132: error: ‘shreeve_buf’ undeclared (first use in this function)
>>> io.c:132: error: ‘hack_buf’ undeclared (first use in this function)
>>> io.c:132: error: ‘horton_buf’ undeclared (first use in this function)
>>> io.c:134: error: storage size of ‘history’ isn’t known
>>> io.c:138: error: ‘CELL_TYPE’ undeclared (first use in this function)
>>> make: *** [OBJ.i386-apple-darwin9.8.0/io.o] Error 1
>>> Stephen Sefick
>>> Let's not spend our time and resources thinking about things that are
>>> so little or so large that all they really do for us is puff us up and
>>> make us feel like gods. We are mammals, and have not exhausted the
>>> annoying little problems of being mammals.
>>> -K. Mullis
>> Stephen Sefick
>> -K. Mullis
