[GRASS-user] Re: r.stream.order problem making on mac os x
Jarek Jasiewicz jarekj at amu.edu.pl
Tue Sep 29 10:34:55 EDT 2009
fixed in svn
William Kyngesburye pisze:
> There should be a crash log for r.stream.order, which you can find in
> your home logs with Console.app.  The trace is especialy useful,
> though the binary images info can be helpful.
> On Sep 27, 2009, at 4:17 PM, stephen sefick wrote:
>> I am building a MacOSX .app and this works just fine.  I can use GRASS
>> and everything that I have tried has worked fine.  The
>> r.stream.extract function worked wonderfully and output raster maps
>> from r.terraflow flow accumulation and direction map.  I tried to feed
>> this into r.stream.order.  I got a bus error on the command line, and
>> in the GUI it just stops.  In both instances I get a ignore report mac
>> GUI message.  This is what I did with the previous ordering software -
>> r.stream, and everything worked fine.  If there is anymore information
>> that I can provide please tell me and I will be happy to provide this.
>> Thanks for all of the help
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is an
> illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
