[GRASS-user] thresh in v.select?
    achim
    ak7 at jupiter.uni-freiburg.de
    Tue Sep 29 05:44:20 EDT 2009
!!! I solved the problem by a workaround:
-> I deleted all lines, whose connected nodes both touch the same area
But the problem itself still exists.
The Problem is:
-I used a line, which crosses an area, to make the area bigger
-Then I tried to delete those lines, crossing and touching the area
-> crossing is no problem, but touching is a problem, I guess because of
in-consistences of roundings
I add an picture, explaining this and I hereby hint at my following mail
concerning with serious problems with rounding-snapping I have.
Markus Neteler schrieb:
> On Thu, Sep 24, 2009 at 2:07 PM, achim <ak7 at jupiter.uni-freiburg.de> wrote:
>> Hi all,
>> I am using grass6.5, so I can use some v.select options.
>> Now I have a general problem with objects that are very,
>> very close to each other: only some digits far behind the
>> comma are different.
>> Is there a way to define the accuracy?
> The code uses Vect_select_lines_by_box():
> http://download.osgeo.org/grass/grass6_progman/vector_2Vlib_2select_8c.html#b1754f710ac2001a10af2ff724d92ff5
> So it takes what it finds. What is the exact problem? That
> it takes too many? A simple example would be useful.
> Markus
-------------- nächster Teil --------------
Ein Dateianhang mit Bin?rdaten wurde abgetrennt...
Dateiname   : touching.png
Dateityp    : image/png
Dateigr??e  : 17503 bytes
Beschreibung: nicht verf?gbar
URL         : http://lists.osgeo.org/pipermail/grass-user/attachments/20090929/99f74c27/touching-0001.png
