[GRASS-user] serious problem with "ROUND-OFF"
achim ak7 at jupiter.uni-freiburg.de
Tue Sep 29 08:14:01 EDT 2009
Thanks, but r.to.vect is not a problem, since I increase the resolution
by 3 and using a script, that produce a correct conversion.
(see picture)
Re: [GRASS-user] Re: IN: raster-flow-direction OUT:vector-network?
Hamish schrieb:
> try temporarily increasing the region resolution by 2x for
> the r.to.vect step.
> Hamish
> --- On Tue, 29/9/09, achim <ak7 at jupiter.uni-freiburg.de> wrote:
>> From: achim <ak7 at jupiter.uni-freiburg.de>
>> Subject: [GRASS-user] serious problem with "ROUND-OFF"
>> To: "grass-user" <grass-user at lists.osgeo.org>
>> Received: Tuesday, 29 September, 2009, 11:01 PM
>> Hi all,
>> I have a problem, I really would like to solve, because
>> many problems
>> occur in my theses in further steps.
>> What I do is:
>> 1. I break lines at some lengths.
>> 2. I use both vector- and raster-data for analysis, which
>> is eg.
>> updating points with raster-values or converting lines and
>> points to raster.
>> The Problems are (due to rounding or "non-snapping"?):
>> !Points from lines on the edge between two diagonal cells
>> (see pictures)!
>> These points do:
>> 1. not belong precisely to one cell (compared with the line
>> they come
>> from (see picture v.to.rast.png)
>> 2. These points sometimes don't lie on on the cells, the
>> line is
>> referred to (see picture break.png)
>> Any hints are very welcomed!
>> Thanks in advance,
>> Achim
>> -----Inline Attachment Follows-----
>> grass-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- nächster Teil --------------
Ein Dateianhang mit Bin�rdaten wurde abgetrennt...
Dateiname   : network_directions.png
Dateityp    : image/png
Dateigr��e  : 105584 bytes
Beschreibung: nicht verf�gbar
URL         : http://lists.osgeo.org/pipermail/grass-user/attachments/20090929/a4bccddb/network_directions-0001.png
