[GRASS-user] grass 7 and ubuntu start up
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Mon Apr 5 17:41:42 EDT 2010
Matthew Mulbrandon a écrit :
> > Just installed grass 7.0 using the latest snapshot binary march 20
> > (grass7.0.svn-i686-pc-linux-gnu-20_03_2010) and ubuntu 9.10.
How did you install grass70?
I type in
> > grass70 in the shell and nothing happens. No error but also no gui. I
> > try some gui commands and it says command not found. Nothing really
> > works but the program seems to activate.
> > I use grass 6.4 often but am at a loss as to what the problem is.
On Thu, 2010-03-25 at 14:31 +0100, Vincent Bain wrote:
> Hi Matthew, just an idea : did you check if grass70 exists in your path and if so,
> is it executable (you can type sth like ls -l /usr/bin/grass* in a term)
Also:
#whereis
whereis grass70
# more options
sudo updatedb # update db for "locate"
# use locate
locate grass70
Nikos
