[GRASS-user] grass 7 and ubuntu start up
Matthew Mulbrandon mulbran at hotmail.com
Mon Apr 5 20:20:37 EDT 2010
Ok this is the error when I start the latest grass7 in ubuntu 9.10 (from below)
matthew at matthew-laptop:~$ grass70
WELCOME TO GRASS              Version 7.0.svn         2010
   1) Have at your side all available GRASS tutorials
   2) When working on your location, the following materials
      are extremely useful:
      - A topo map of your area
      - Current catalog of available computer maps
   3) Check the GRASS webpages for feedback mailinglists and more:
      http://www.grass-gis.org
      http://grass.osgeo.org
Hit RETURN to continue
Starting GRASS ...
  File "/usr/local/grass7.0.svn-i686-pc-linux-gnu-20_03_2010/etc/wxpython/gis_set.py", line 825, in <module>
    GRASSStartUp = StartUp(0)
  File "/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7978, in __init__
    self._BootstrapApp()
  File "/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py", line 7552, in _BootstrapApp
    return _core_.PyApp__BootstrapApp(*args, **kwargs)
  File "/usr/local/grass7.0.svn-i686-pc-linux-gnu-20_03_2010/etc/wxpython/gis_set.py", line 796, in OnInit
    StartUp = GRASSStartup()
  File "/usr/local/grass7.0.svn-i686-pc-linux-gnu-20_03_2010/etc/wxpython/gis_set.py", line 163, in __init__
    self._set_properties()
  File "/usr/local/grass7.0.svn-i686-pc-linux-gnu-20_03_2010/etc/wxpython/gis_set.py", line 210, in _set_properties
    self.OnSetDatabase(None)
  File "/usr/local/grass7.0.svn-i686-pc-linux-gnu-20_03_2010/etc/wxpython/gis_set.py", line 655, in OnSetDatabase
    self.UpdateLocations(self.gisdbase)
  File "/usr/local/grass7.0.svn-i686-pc-linux-gnu-20_03_2010/etc/wxpython/gis_set.py", line 533, in UpdateLocations
    self.listOfLocations = utils.GetListOfLocations(dbase)
  File "/usr/local/grass7.0.svn-i686-pc-linux-gnu-20_03_2010/etc/wxpython/gui_modules/utils.py", line 557, in GetListOfLocations
    for location in glob.glob(os.path.join(dbase, "*")):
  File "/usr/lib/python2.6/glob.py", line 16, in glob
    return list(iglob(pathname))
  File "/usr/lib/python2.6/glob.py", line 43, in iglob
    yield os.path.join(dirname, name)
  File "/usr/lib/python2.6/posixpath.py", line 70, in join
    path += '/' + b
UnicodeDecodeError: 'ascii' codec can't decode byte 0xd0 in position 2: ordinal not in range(128)
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue...
mkdir: cannot create directory `/tmp/grass7-matthew-11707': File exists
Cannot create temporary directory! Exiting.
Cleaning up temporary files ...
access: No such file or directory
ERROR: LOCATION << /home/matthew/<UNKNOWN> >> not available
Starting GRASS ...
/home/matthew/<UNKNOWN>/<UNKNOWN>/.gislock: No such file or directory
ERROR: /usr/local/grass7.0.svn-i686-pc-linux-gnu-20_03_2010/etc/lock:
Unable to properly access /home/matthew/<UNKNOWN>/<UNKNOWN>/.gislock
Please notify system personel.
matthew at matthew-laptop:~$ ^C
Again any help would be great as I do not know were to start.
Thanks,
Matthew
> Subject: Re: [GRASS-user] grass 7 and ubuntu start up
> From: nikos.alexandris at felis.uni-freiburg.de
> To: bain at toraval.fr
> CC: mulbran at hotmail.com; grass-user at lists.osgeo.org
> Date: Mon, 5 Apr 2010 23:41:42 +0200
> Matthew Mulbrandon a écrit :
> > > Just installed grass 7.0 using the latest snapshot binary march 20
> > > (grass7.0.svn-i686-pc-linux-gnu-20_03_2010) and ubuntu 9.10.
> How did you install grass70?
> I type in
> > > grass70 in the shell and nothing happens. No error but also no gui. I
> > > try some gui commands and it says command not found. Nothing really
> > > works but the program seems to activate.
> > > I use grass 6.4 often but am at a loss as to what the problem is.
> On Thu, 2010-03-25 at 14:31 +0100, Vincent Bain wrote:
> > Hi Matthew, just an idea : did you check if grass70 exists in your path and if so,
> > is it executable (you can type sth like ls -l /usr/bin/grass* in a term)
> Also:
> #whereis
> whereis grass70
> # more options
> sudo updatedb # update db for "locate"
> # use locate
> locate grass70
> Nikos
_________________________________________________________________
The New Busy is not the old busy. Search, chat and e-mail from your inbox.
http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_3
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100406/fd42c21a/attachment.html
