[GRASS-user] how to import .shp and .dbf files???
    M S
    mseibel at gmail.com
    Thu Apr  8 10:24:14 EDT 2010
If you are sure the projection of the shapefile matches the projection of
the location, you can use the -o option to override that check.
Mark
On Thu, Apr 8, 2010 at 10:20 AM, Nadine Jeschke <blaubaere at gmx.de> wrote:
> Hi Mark and António!
> I´ve tried to use "v.in.ogr" but it didn´t work. The report says "the
> projection of the dataset ist not identical with the projection of the
> location"
> Do I have to install GDAL first??? That´s what I found at this page:
> http://grass.itc.it/grass62/manuals/html62_user/v.in.ogr.html
> Nadine
> Am 08.04.2010 um 14:27 schrieb M S:
> Are you using v.in.ogr?  If so, are you pointing the 'OGR datasource name'
> to the .shp file?
> Mark
> On Thu, Apr 8, 2010 at 7:59 AM, Nadine Jeschke <blaubaere at gmx.de> wrote:
>> Hi to everyone!
>> I´m working with grass 6.3.0 on a ibook and I´d like to import some files
>> with .shp and .dbf format but I always get the report: "not recognised as a
>> supported file format"
>> Are there some applications missing? Hope somebody can help!
>> thanks!!!
>> Nadine
>> GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
>> Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100408/47d27d8f/attachment-0001.html
