[GRASS-user] Using v.surf.rst
Eric
temp at johannsen.us
Thu Apr 8 21:31:09 EDT 2010
I'm very new to GRASS and an experienced programmer.
My goal is to import isolines (elevation lines) as well as elevation points
from another mapping program into GRASS and then interpolate a raster based
on the vector data and then export as a DEM file.
To that end I have reviewed
http://grass.osgeo.org/grass64/manuals/html64_user/v.in.ascii.html
http://grass.osgeo.org/grass64/manuals/html64_user/v.surf.rst.html
I think I understand the principals but am getting stuck on several details.
As a simple test I attempted to create an ASCII file with X Y Z coordinates:
myFile.txt
593493|4914730|123
591950|4923000|222
589860|4922000|232
590400|4922820|143
593549|4925500|442
600375|4925235|342
import with
v.in.ascii -z input=myFile.txt output=secondTry z=3
I get v.in.ascii complete (no error messages)
and then
run v.surf.rst input=secondTry at PERMANENT elev=secondTryRaster
This yields the error
some points outside of region -- will ignore...
there are points outside specified 2D/3D region--ignored 6 points
ERROR2: zero points in the given region!
ERROR: Input failed
Keeping in mind I'm completely new to GRASS (and don't understand a lot of
the jargon), can you explain what I'm doing wrong?
Also, can you recommend a tutorial that covers this type of conversion
oriented toward beginners?
Thanks!
Eric
After importing the data points, I do not see anything at all visually in
GRASS GIS Map Display.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100408/ee407057/attachment.html
