[GRASS-user] v.net.iso - service area
Markus Neteler neteler at osgeo.org
Fri Apr 9 10:09:12 EDT 2010
would you mind to write a smal FAQ for us?
http://grass.osgeo.org/wiki/Faq
Thanks
Markus
On Fri, Apr 9, 2010 at 2:51 PM, Johannes Sommer <johann.online at gmx.de> wrote:
> David,
> thank you very much! I tested your approach with network isolines
> derived from a dataset with one center - and it worked very well!
> The automated approach will be interesting (also with more than one
> center) - but therefore I need more experience in GRASS scripting.
> thanks,
> Johannes
> David Mahoney schrieb:
>> I went through this last year, and as I remember, v.hull doesn't quite
>> get you there, since the resultant polygon can't "dip in" to reach
>> concave sections of a service area. I used v.delaunay to create a
>> network of the nodes that made up the connections between service areas,
>> and v.net.salesman to generate the edges of the service areas.
>> David
>> On Mon, 2010-04-05 at 09:04 -0300, Daniel Victoria wrote:
>>> If I understand you correctly, v.hull might help to create the service
>>> area polygon from the points....
>>> http://grass.itc.it/grass62/manuals/html62_user/v.hull.html
>>> On Sun, Apr 4, 2010 at 8:12 PM, Richard Chirgwin
>>> <rchirgwin at ozemail.com.au> wrote:
>>>>> Message: 3
>>>>> Date: Sat, 03 Apr 2010 23:11:26 +0200
>>>>> From: "Johannes Sommer" <Johann.online at gmx.de>
>>>>> Subject: [GRASS-user] v.net.iso - service area
>>>>> To: grass-user at lists.osgeo.org
>>>>> Message-ID: <20100403211126.313360 at gmx.net>
>>>>> Content-Type: text/plain; charset="iso-8859-1"
>>>>> Hi list,
>>>>> recently I played around with the network functionality in ArcGIS. I
>>>>> generated so called "Service Areas" in a network dataset which return the
>>>>> regions that can be accessed in a network dataset based on several distances
>>>>> (in my example 150, 400 meters).
>>>>> I wanted to reproduce the results with GRASS GIS and after a short search
>>>>> I found the module v.net.iso which seemed to fit my needs. It returns
>>>>> exactly the same results as ArcGIS did on isolines on a network, but I can't
>>>>> find any solution concerning the service areas.
>>>>> Can anyone point me in the right direction to calculate zones (that is
>>>>> "build polygons from the end points of each network segment") from these
>>>>> generated isolines in a network?
>>>>> Regards,
>>>>> Johannes
>>>> Johannes,
>>>> I don't think there's anything to do this automatically in Grass-GIS. But I
>>>> think you should be able to construct a script that would connect pairs of
>>>> points.
>>>> So if you can extract each end point of the network segment, you would end
>>>> up with a vector containing only points - then create a temporary map of a
>>>> point pair, run (say) v.distance output=connectors on each point pair, patch
>>>> the resulting maps together ...
>>>> It sounds a bit labourious, and probably someone else can think of something
>>>> easier, but if you get all the individual steps right, a script is then easy
>>>> to create.
>>>> (Actually, Johannes, I think the idea is brilliant. I've done lots of
>>>> network service area work, and it never occurred to me before!)
>>>> Richard Chirgwin
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
