[GRASS-user] v.net.iso - service area
Richard Chirgwin
rchirgwin at ozemail.com.au
Fri Apr 9 18:16:54 EDT 2010
David,
I'd just like to confirm the process ...
1. Obtain points you wish to use as the service area edge nodes (I will
call this vector "Limit").
2. Run v.delaunay to create a vector that includes the outline
(map=Delaunay).
3. Run v.net to connect Limit to Delaunay (map=Network)
4. Run v.net.salesman on Network to create the final service area map.
This seemed to work fine for me in Spearfish.
One question - I created the "point set" manually. But if have a network
of lines, what's the best way to create a point vector from the line ends?
Richard
Markus Neteler wrote:
> Hi,
> would you mind to write a smal FAQ for us?
> http://grass.osgeo.org/wiki/Faq
> Thanks
> Markus
> On Fri, Apr 9, 2010 at 2:51 PM, Johannes Sommer <johann.online at gmx.de> wrote:
>> David,
>> thank you very much! I tested your approach with network isolines
>> derived from a dataset with one center - and it worked very well!
>> The automated approach will be interesting (also with more than one
>> center) - but therefore I need more experience in GRASS scripting.
>> thanks,
>> Johannes
>> David Mahoney schrieb:
>>> I went through this last year, and as I remember, v.hull doesn't quite
>>> get you there, since the resultant polygon can't "dip in" to reach
>>> concave sections of a service area. I used v.delaunay to create a
>>> network of the nodes that made up the connections between service areas,
>>> and v.net.salesman to generate the edges of the service areas.
>>> David
>>> On Mon, 2010-04-05 at 09:04 -0300, Daniel Victoria wrote:
>>>> If I understand you correctly, v.hull might help to create the service
>>>> area polygon from the points....
>>>> http://grass.itc.it/grass62/manuals/html62_user/v.hull.html
>>>> On Sun, Apr 4, 2010 at 8:12 PM, Richard Chirgwin
>>>> <rchirgwin at ozemail.com.au> wrote:
>>>>>> Message: 3
>>>>>> Date: Sat, 03 Apr 2010 23:11:26 +0200
>>>>>> From: "Johannes Sommer" <Johann.online at gmx.de>
>>>>>> Subject: [GRASS-user] v.net.iso - service area
>>>>>> To: grass-user at lists.osgeo.org
>>>>>> Message-ID: <20100403211126.313360 at gmx.net>
>>>>>> Content-Type: text/plain; charset="iso-8859-1"
>>>>>> Hi list,
>>>>>> recently I played around with the network functionality in ArcGIS. I
>>>>>> generated so called "Service Areas" in a network dataset which return the
>>>>>> regions that can be accessed in a network dataset based on several distances
>>>>>> (in my example 150, 400 meters).
>>>>>> I wanted to reproduce the results with GRASS GIS and after a short search
>>>>>> I found the module v.net.iso which seemed to fit my needs. It returns
>>>>>> exactly the same results as ArcGIS did on isolines on a network, but I can't
>>>>>> find any solution concerning the service areas.
>>>>>> Can anyone point me in the right direction to calculate zones (that is
>>>>>> "build polygons from the end points of each network segment") from these
>>>>>> generated isolines in a network?
>>>>>> Regards,
>>>>>> Johannes
>>>>> Johannes,
>>>>> I don't think there's anything to do this automatically in Grass-GIS. But I
>>>>> think you should be able to construct a script that would connect pairs of
>>>>> points.
>>>>> So if you can extract each end point of the network segment, you would end
>>>>> up with a vector containing only points - then create a temporary map of a
>>>>> point pair, run (say) v.distance output=connectors on each point pair, patch
>>>>> the resulting maps together ...
>>>>> It sounds a bit labourious, and probably someone else can think of something
>>>>> easier, but if you get all the individual steps right, a script is then easy
>>>>> to create.
>>>>> (Actually, Johannes, I think the idea is brilliant. I've done lots of
>>>>> network service area work, and it never occurred to me before!)
>>>>> Richard Chirgwin
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
