[GRASS-user] Using v.surf.rst, Part II
Eric
temp at johannsen.us
Fri Apr 9 21:25:04 EDT 2010
Awesome! Importing the points worked.
My real source data is defined as a combination of points (which I can now import) and 2D splines (representing the isolines) that may or may not form a closed shape, like this:
|2D Smooth Polygon:
| Height 2885
| smoothing method: Cubic B-Spline
| node 1 at 564.51807,742.19873
| node 2 at 249.51805,570.15057
| node 3 at 578.43365,137.50000
| node 4 at 919.99994,451.23495
| node 5 at 708.73486,742.19879
| node 6 at 541.74695,727.01807
I can easily reformat the data.
How do I import a spline like this into GRASS in preparation for v.surf.rst (or other vector to raster methods)?
Thanks!
Eric
