[GRASS-user] Spgrass6 and R using GRASS Bash Scripts
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Fri Apr 16 09:34:09 EDT 2010
Hi Gilbert,
There ist more than one way. I will tell you the way that works for me:
0. Be sure your Rgui.exe are in the windows path like
C:\Program Files (x86)\R\R-2.9.0\bin
1. Start grass/MSYS (sorry, I am on windows).
2. Connect to you mapseet
3. inside MSYS shell type:
Rgui.exe&
4. Inside R you can run your scripts like:
#this is on R
require(spgrass6)
gmeta6()
myMap=readRAST6(...)
summary(myMap)
system("g.list.exe rast")
-- But I know that the way I do are not updated :-)
cheers
milton
2010/4/16 Gilbert Ferrara <gilbertferrara1974 at gmail.com>
> Good Morning
> I need to do something similar to what Neteler/Mitasova do in their book
> with spgrass6 and R. Since I will have to perform this a couple of times I
> want to build a simple Script with input/output GUI. But I have never seen a
> GRASS Bash script that calls R and spgrass6. So my question is? Does anyone
> have/knows one? If not, I just need to send to the command line exacly the
> same commands? e.g. R , summary(data) )
> Thanks
> Gilbert
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100416/b7353187/attachment.html
