[GRASS-user] algorithm used in i.cluster
Georg Kaspar
georg at muenster.de
Wed Apr 21 11:29:09 EDT 2010
hi,
a quote from Markus' "Introduction to GRASS GIS Software" (1998):
"[...] GRASS uses the "minimum distance to means" algorithm for deriving
the clusters [...]
"minimum distance to means" is described in Lillesand and Kiefer (2000),
as a supervised classification technique which requires a priori
information. Does the i.cluster module use a modified version or have
there been changes since 1998?
the manual page does not contain any further information on how the
module works...
does anybody know which exact algorithm is used (k-means probably...)?
thanks & regards,
georg
